Airhead
  1. might be worth sending member 'speedshop' a PM, I think they repair CDI's...worth asking anyway. Oh and save a search on ebay
  2. Greetings dan, good luck tomorrow
  3. greetings mate i hope the username isnt indicative of the new bike
  4. nice one phil a great holiday and quids in with the DT parts
  5. Aaghh thats a bummer mate but the main thing is youre ok yourself. Try fowlers of Bristol for yamaha parts or your local dealer wemoto is woth knowing about for general stuff My Wemoto link
  6. not studied the panel yet NEV will let you know, as for vibration...wot a 600 single II know what you mean Jason, its a completely different ride to the strokers, just fancied a change y'know
  7. wemoto is worth a bookmark dan My Wemoto link
  8. salz clutches usually have an adyustment (not cable adjustment) sometimes there is a pointer on the clutch arm and a mark on the casing that must align if you push the arm until it stops. I suggest you get a Haynes manual and have a look-see.
  9. Greetings 96V and been a lovely day here for once
  10. sounds like a similar issue to this thread here and may need the clutch adjusting (not just the cable slack) as merv says you would get great advice on the aircooled rd forum
  11. Rachael here is a diagram of the parts involved Click on the Starter tab %201A3RM-300EA/STARTER/"]My link you will need to buy a kicker mechanism (see other link) and the oil seal numbered 18 in the diagram, you will have no trouble finding the lever on ebay I found this http://www.ebay.co.uk/itm/kick-start-shaft-dtr-125-yamaha-/330595316844?pt=UK_Motorcycle_Parts&hash=item4cf904346c
  12. is the plug getting wet bill? these bikes dont have a crankcase drain, you have to leave the plug out and let it stand for quite a time until it evaporates off. so you need fuel? spark? and compression? but i expect you know that already.
  13. Here she is, today cost me a new chain and sprocket set and the guys at Terry Sivester's worked wonders removing a seized wheel adjuster bolt. Ordered a new healight cowl and plastic dash which was broken.
  14. Greetings salz along.
  15. I do too cynic, i said a foot pup but in reality i use one 'o' them They are know as 'Track pump'
  16. yeah I have the same problem with my bandit, now i pump them up at home with a footpump or one of the car pumps that plug into a lighter socket.
  17. no mate theres no shaft there but i think the cases are machined to accept the mechanism and the outer case just has a bung in.
  18. yes i believe it can be done rachael using kicker mechanisms from dTR's ...cant believe just how much you are paying for work in this thing
  19. Looks a clean example sammy, 2 stroke with a shaft drive eh...a rare combination.
  20. is the DEP silencer oiled up? you may have to have it re-packed, or re-pack it yourself
  21. Airhead replied to Pizzle--!!'s topic in Projects
    Thats right pizzle, just have a ride down and ask them first, if they will oblige remove the cover and hey presto. yeah then have them just nip it up so you can get home
  22. Oohh I would love to see the 'forbidden fruits' ones
  23. Yep thats looking real nice John. Liking the red colour too.
  24. Airhead replied to up.yours's topic in The Bar
    £300, cant be bad if its not a rust bucket.
  25. Airhead replied to Pizzle--!!'s topic in Projects
    Yeah in the past I have ridden my bike to a local tyre fitting bay to do that, of course I dont own a rattle gun but they do. They would usually oblige.
