Airhead
  1. Have a great day drewpy
  2. hmm could be a crank seal issue?
  3. in the past i have rounded off the hexagon on the bowl because i used open ended or 12 point ring spanners...i learned my lesson and now i would use a 6 sided socket commonly found with 1/4" drive
  4. blocked pilot jet? how does it seem with choke?
  5. yeah i'm thinking of the explosion risk, what if there were a spark inside...I figured rightly or wrongly that something that couldnt be ignited with a match...ie not vapourising...would be safer, I would be concered with using thinners unless it passed the lighted match test but hey I'm no expert so how is the petcock fixed to the tank? pehaps for safetys sake stick with water (de ionised) and then rinse out and shake some WD40 about in there to prevent rusting?
  6. not sure about the petcock...do you mean to remove it from the tank or to strip the thing down? also not sure about using water in the tank, how about using fish tank gravel and paraffin (kerosene) or WD40? I appreciate that you wouldnt want to use something too volatile but you can toss a lighted match into a container of kerosene and it will extinguish it wont it?...waddya think? i've never had to do this kind of work myself but if i were to go down this route i would prbably not use anything that would ignite by a lighted match............how volatile would laquer thinner be?...take care!
  7. Airhead replied to Noise's topic in Yamabyss
    ahh...saw the title and thought you had a nutter to deal with
  8. no mate mine works from good ole gravity seems a few YBR's also suffer from this!!
  9. what is it about yamaha fuel pumps and warm weather???!!!
  10. I say you still need to check the flywheel...is it loose? has the key sheared?
  11. Foamy did you get Alex's message?...The url is yamahaclub.com Large white with Airhead on the back please,,,my mate Alex is buying
  12. Love it! :spin2:
  13. great stuff andy, look forward to seeing you progress with this
  14. Greetings Natalie post up a piccy then
  15. how come its the piston corey? is there good compression...i suppose theres no kicker on such a modern bike?
  16. dont blame you mate, i'd have done the same myself
  17. and the flywheel key, which only cost pennies????????
  18. nice one deon..., how you finding the beast then?
  19. poke something down the hole through the outer case as well to find the depth and fit a screw 5mm shorter than what you find
  20. you may get screws from yambits jamie
  21. Greetings and welcome Luke
  22. another likely culprit is the flywheel rotor has not been torqued up to the required specification and has sheared the woodruff key!
  23. i dont think carb gozz, more electrical. Have you a spare CDI or any mates have one on their bikes...to try?
  24. yeah not a bad way to spend a few hours, the tracker got some admirers as it always does, some nice brit iron there too eh
