blackhat250
  1. Thats not the clutch side , thats the ignition rotor,
  2. Welcome ike" ,, you"ve got the resto bug i see,,
  3. blackhat250 replied to YamYamMan's topic in General
    Good you"v got sorted, the main jet has no bearing on low engine speed. only wide open throttle. pilot jet & air screw determine idle and first 1/4 of throttle opening,,
  4. Ah , that be the silver 1G1 . then,,
  5. Stick my hands on the cylnder heads to warm gloves, when its cold, [ thats most of the time up here]. then read the opisite lights, and time it for the take-off,
  6. Welcome wade " must agree about the vital statistics, " i think this should be mandetory ,,,
  7. Welcome mark, ,, fire tech questions in workshop, or search for them ,as most subjects have been covered,,
  8. Hee " can"t hide anywhere nowadays,,, .. hand over back of carb was to increase vacume,,
  9. Yeh ,,, the 1975 DT175/125 B model fits, but not the CT1-3 models, they are narrow underneath,, .why do you want to change,,
  10. Yeh plates wil be stuck, put front wheel against wall, ,and with lever pulled in select gear,, if that dont work ,, strip needed, them air joints on carb look iffy, and stock air filtre would be better, to solve the running issues ,
  11. Buy a multi meter, there cheap. chances its a bad earth, un bolt it ,clean it and remount it,
  12. Aye dave " check that chain for seized links, ditch it, coz there about £20. for them dt"s . rust , man hasn"t found a cure for that yet, cure for cancer will be found first,
  13. Welcome 96" as he says take out the pilot jet, clean it till all holes are clear, the carb bottom will have a well with small hole in bottom, this feeds the choke jet, blast it thru with carb clean, .air screw will be 1.5 turns out,
  14. Welcome catto " yip seems like good enuff stuff, i"v dealt with jls, before , good seller,,,
  15. Acording to Stan [ stephens] the man,, its not the earth strap [ tip] that the colour is , its the threaded area, and yours looks Blackish,, rich then,,, also he says W.O.throttle, but not full revs, if you know wot he means,,
  16. Looks very nice "
  17. blackhat250 replied to Noise's topic in Yamabyss
    Great pics " Seams to be a marital thing ongoing " so heres me [ white flower] with me bro" waiting on the bride, 20years ago . And 20years later. getting me wallet out, at the 2 stroke meet.
  18. Yeh yer right, a fair selection of different engine configuration ,,, welcome too ,,
  19. I think this has always clashed with our Squires meet, 1st weekend in september, as i always see them heading to Barnard castle,,,might be different this year tho..
  20. Welcome gatens " good choise,,,
  21. blackhat250 replied to blackhat250's topic in General
    Yip " thats the bugger Dunton Basset. , pity i neve knew you Eddy, The bike section was poor, A rocket 3 . and a CB200. i mind seeing,,
  22. Welcome jeroen " parts might be hard to find,,, the mods will help with that photo i hope...
  23. He wants to get jeans that fit him,, yuk "
  24. Welcome Ste " a bit more info would help with conversation, ,,
  25. Weel its about 3 weeks away, am planning on being there friday, 5 pm ish, Scott SS50 will be with me, in van. or trailer,
