It's a sad day but he left a great legacy
That was my intro to them as well.... Chickrn sheish is better tho...
Spark plug experiment.
Phew, thats hot,, mines is deffo Farenheit , as its at 49 degree in shed at the moment.. Aluminium melts at 650* F,,,
Corbstar. Dt 400 B uk
Welcome cobstar " is your DT400 in black,,,the UK..or yellow...?
Bikers in cinema
Great ending" hats off to them couples ,,,
Y think there all different, Pauls DT ran 230*f - with a max of 270*f , so you can imagine how i felt today when 300 was surpassed. But shes been good all 2000 + mils this year... was surprized at B8es figures , . I did notice when at traffic lights or junctions , the temp rapidly fell.. i thot it would heat at lights, [ aircooled mind] It give you more confidence , on a long hill climb Newman,,, watching , and knowing the limits,
battery or not to battery?
What volts is the battery showing , after the attempts,,,,?
I installed the temp [ plug] sensor on Ts250 today,,, Ran 15m;s outward & 15 back , First run with NGK B7ES [ standard for model] , Results,,,,, @ 50mph reading- 315 *f ,,, At 60 uphill, it maxed at 337*f. 2nd run- NGK B8ES reading- @ 50mph 280*f... @ 60Mph up hill = max- 308*f. There was no difference in performance, only cooler , Gonna try jets next... Interesting stuff,
yamaha xj600 club meetings in essex
Hi kev" post a ride-out meet , thers a few members in that area,,, time of year now limits & daylight,
squishy earth
I see " move the moon,,, bash the planet,,,
Bikers in cinema
http://www.theinspiration.com/2011/09/carlsberg-stunt-in-cinema
UK - clocks changing this weekend
Yip ,,,Garage time,,,,,
4dl new member
Hi adam,,,, not familiar with the model . post up pictures in project section,,, till we see her,,,,
YBR 125 Cutting out
- The Cursed XT 125 X
Good news grouch"o, if its the gear shaft thats snapped , its easy , as it passes thru the cases, with the pawl on one side, only side case removal. and clutch, to access ...- Yamahead
- S10 new owners
Hi davey,,, you"v had most models,, , , you"l have more experience than us,,, welcome.. . any input welcome..- Difference between ct3 and dt175 ?
Post up the frame number mark,,,and we"l see what model & year it is,,, not in here tho , go to projects ,or workshop,,- New old member 2
Welcome dutch" good wee bike the XT250 ... gold wheels too.? and great classic the FJ ...- Prog
Fixed it tommo" ... nice job madug " is paint made up,,, mot standard engine gloss, heat res....- Yl-1 Transmission Problem
Dirty is on the right track,,, shift pawl / return spring .etc. why you got ATF in box,,, put in correct SAE. it will help ,,, Welcome bye the way...- which old duffers remember this.
How does it not embed automatically, it used to.. and i was at technical collage at this time ,,, awaiting the punk erra- DT175 Flooding
Hoo ray " its a learning curve,,, for us all,,,, thats a new one [ fault...]- New old member
Welcome craIG " ther was a few nice Xj900"s at Stafford show at weekend,,,- I served someone famous today!
Brilliant he was " " did you like that "- New bike - sore hips
Yes dan" its muscles you"v not used probably.... is it cramp ,,,or just ache ? - The Cursed XT 125 X
