blackhat250
  1. Hi shad " yeh the DT"s have a strong following on here, .. thats a good find ,,
  2. What next on the list then ? av sold the Zed too ,,,
  3. Welcome,, ,hows the MT ? any bad points..
  4. Sad loss " i knew he was critical ,,
  5. Hi bernie" maybe a fly screen will help , i rode one over to Ireland ,,, great handling machine,,
  6. Hi SGF" Thats a great bike you"ve bought , welcome aboard,,
  7. Yeh neil" great intro. a lot of us are beck on bikes after a long spell off , enjoy the summer, looks like its gonna be a long one . for you southerners anyway,,
  8. Is there spark " and were the plugs wet when removed,,
  9. Aha" this is like my H2 ,, the kickstart is on firstgear via the cluch-primary gear to start engine , pull in clutch -and kicker just slides. You need her in neutral. same if you stall the bike at light, .. be ok when electric start works,
  10. Aye tommo" theres a lad showing interest,, Awaiting his call . av got me eye on summat else .
  11. Throttle cable route ,,, And an intro will be good, ,
  12. Hee " can"t wait to see Cynic answer that ,, . Your right about the Zed , heavy bastewrt, The H2 with brembo brakes firm rear shocks and Avon Roadriders , would surprize you
  13. Yeh" helicoil kit.. gives you drill bit - tap -insert- tab breaking tool. you can get it right, without guess work,, http://www.ebay.co.uk/itm/RDGTOOLS-M6-X-1-HELICOIL-KIT-THREAD-REPAIR-KIT-/370774984037?pt=UK_Hand_Tools_Equipment&hash=item5653e94565
  14. Hi claire " wheres up north are you,? seen your post , on mantainance , Wd 40 be another asset,,
  15. Welcome in Matt" that be the Shaft drive Xs , post up some piccy"s. and get a topic started , help will come along..
  16. Hi felix" good to see your weathers perked up too, i see your gaining experience,,
  17. Hi gaerc" small puller needed,,cheap too.
  18. Hi ressie, rotherham made it then, . i backed them,,,and Leyton O. & derby, but that QPR let me down for £672. the useless fookers,,
  19. Yeh laserna " more info....
  20. Where are you Matt" Tomintoul area,?
  21. Hi claire , i would say a good set of tools , and patience is the order, .. and autosoll. What about a piccy ,,,
  22. Aye martyn, does it smoke on startup. .[ arter sitting] valve stem seals will be culprit,, look for smoke on startup. and sweet smell. "not as Sweet as 2stroke tho." .
  23. blackhat250 replied to bippo's topic in The Bar
    Yeh" well done, ,,think of the traffic down there,,
  24. Hi lincol.. . yeh input welcome,,
