blackhat250
  1. Been a great Sept,, and no rain ,for two week ,...
  2. Ask in here, lots of model info ,, http://yamaha-enduros.com/index.php/forum
  3. Yeh dave " those small needle bearings , are submerged in oil. and just locate the shafts in cases, never heard of them worn out, the big bearing [output. behind the sprocket] can get stress, with overtightened chain
  4. Hi tom " there a rebust motor,, the only thing I can see, is the crank seals my be hardend ,due to standing, this will surface when shes running, as when she warms up, the idle usually creeps up , as air seeps by the seal.[ L/H ] generator side, the r/h will suck gear oil if its gone, [ white strong smelling smoke] . but you may be lucky, strip that carb, and clean the jets ,, that's a must
  5. Hi there, member Wild foamy, is a guru on dt50"s...
  6. Hi ben " 180miles ...wow, someone never rode a lot,,, or it rains worse in that state, than up here,,
  7. blackhat250 replied to Noise's topic in The Bar
    Get the welder oot . ....
  8. 60Th anniversary colour,,,,
  9. Ay -up.... lots of DT fans in here, also, ,,,http://yamahadtclub.proboards.com/
  10. Hi Jason ", check out Fizzy splitters forum, all the correct info ,
  11. Hi brian . re-chrome , I use Agbrigg , best parts soarse is E-bay, -yam-bits -Uni-parts,
  12. http://www.vice.com/en_uk/read/blackburn-man-does-five-lines-of-cocaine-has-a-forty-minute-wank-in-a-beer-garden-is-arrested-303
  13. Hi venge" did you get an answer . ?
  14. Its rivits aint it simon, some baskets have rubber cush , they can be rebuilt, . this slack is usually felt in the clutch lever, [ kinda delay in feel ] never done a rebuild, but seen a thread on 2stroke forum , [ rd400 basket.]
  15. Hi elvy, . Rex speedshop do new replacement cdi setup, much better, , your need you flywheel. that's all , his supply stator plate ,and soarce coil. no pulser coil needed, .
  16. Welcome rembrant " .
  17. Welcome inn , matt ...
  18. Aye slice. that's remote, ,no phone signal either, town about 25mls away, fuel .. farther afield, these" small villages have no pump at them , nearest Mc donalds . 60mls,,,
  19. Here JIM, Glen Lyon. Machless, Ajs - and twa Trumpets,
  20. Drewps " I just love that twin headlight look, [ pure 1980"s] Tommo " your a square,,,,,,
  21. Kev ,that's amazing milage wi the Jawa,,,,proof that 2 strokes are durable ,, I"l see if I can find a picky of you on her,,, yeh here ,,,,
