blackhat250
  1. Well done torkorp" sounds great ,, good workout on that hard bumps,,,
  2. Yip DT125 Lc MK2 1985/6...
  3. OK" piccy 2 , the cable should go into a splitter under tank, same place as throttle cable. piccy 3 , is the oil feed to carb, or banjo on crank case, Run this bike on pre-mix till this is sorted.. 4600 mls is low, for a bike this age, it looks like an 1980"s style,
  4. Now neo" it was 17 degrees in Lomdonshire mid-week ,,
  5. Welcome harv" What model is yours, the AT2E & AT3E have a starter generator, whitch have brushes 4 of, Other models have magnito / charging coils ,[ 1 coil in UK dt models,]
  6. He mean Auto"s ,,, . Bikers always call them cages " see where were coming from, welcome by the way , spoke to you in chat, already
  7. Heres another usefull page, to tune carb after removing airbox, , My ZL900 ws overich when i got it, [black sooty exhausts,] i removed air filtre , and a massive improvement , took carbs off to set float level, and checked the pilot screws, 4 turns out, [ that richens these carbs,] set them back to 2&1/8. and problem solved,,, ..read this page,, http://bikeadvice.in/fit-kn-filter-rejet-carburetor/
  8. Yeh " turn carbs up , and screw should be in a deep well, [ sometimes a plug needs to be removed to see them , ] located at front side of bowl, [ not bowl itself,] screw them fully home , then turn them, out 2 &/18 turns, Look a diagram , pilot screw, [ in small box to left] thers a rubbers stopper, then screw, ] http://cdn.cheapcycleparts.com/images/KA/61790.png
  9. Davie," heres some spec , The Pilot Air screw is what i mean, 2 1/8 turns out, ,Access to them is below,... Make - Keihin/CVK 32 Main jet- 125 Air jet- 130 Jet needle- N27N Pilot jet- 35 pilot air jet- 125 Pllot Screw - 2 1/8 Turns out Float height - 17mm
  10. Well done davie" whats in the glass Ardbeg" oh what do you mean not proper seated , looks ok,,, them are the same carbs as my illiminator, ZL900, see how the breathers are all top mounted, same as fuel inlets, Aye " and air screws are on bottom side, so adjust to book settings before intalling,,
  11. Hiya ken" ex mayor of London is it, Great indepth intro by the way,,,
  12. blackhat250 replied to Grouch's topic in The Bar
    Be ok on Harley"s then,,,
  13. Fk me Grouch"o , don"t waste your money on a Lotto ticket either, , what a bummer,, ,
  14. blackhat250 replied to BillyBennett's topic in The Bar
    Sounds like it bill, i thoght the"yd keep expansion tank beside Rad, but there you go... designer"s for yeh,,
  15. blackhat250 replied to Sacha's topic in Projects
    Fomeh" you"ve been reading that Shavin Ravin mag again, back in your box, Now back on Topic " sash" hows your seat,,
  16. Well davie , how "d it go ? i see the join in the table , you plonker dr ewps,,,
  17. Well done john" i remember you looking for 1 , is it the Uk black/ white, or Usa Yellow, ? I sold mine on, it ended up in that dealer in London [Frank 1] it was a minter too, .
  18. blackhat250 replied to BillyBennett's topic in The Bar
    Na " tank up front will be coolant tank,,[DT LC] I take it, am not a modern bike expert, but thats my guess ,,
  19. Thats a stunner" whats the brick for " i never got 1 o" them with mine, stand too short , or its been lifted.
  20. blackhat250 replied to BillyBennett's topic in The Bar
    Am up N/E scotland,,, 500mls north of you, i see it was 17 degree"s in london yest,, jammy sods, is that the oil tank up front ? usualy below seat, ,, you know the gearbox is separate oil level on a 2 stroke then,, check that too.
  21. blackhat250 replied to BillyBennett's topic in The Bar
    Aye billy" you should have a 2 stroke oil tank, and don"t need pre-mix, look for the filler , and check the level, And the forcast is freezing this weekend,,,
  22. Aye davie " soak rubber in Warm water, then fit it, i had a new whole slide, and a mate took it for his GPZ 600 , he say you can still get them,, am awaiting its return,, are you at the show this weekend,
  23. Hi ther " be more specific" Idle - is it ok when cold ? when warm is it reving higher, Cutting out ? is it 4 stroking [ spluttering] at what revs, and does it die completely.? How long has it been standing without use ? = fuel petcock remove and clean , carb off and take out ALL jets, - set air screw to manual settings, then we"l talk crank seals,,
  24. Never saw one one the road in the 70"s .. adverts at the time tooted about it,, http://www.ebay.co.uk/itm/230938525571?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
  25. How do yeh know its goosed " it might be Mains just, ,, or have yuo got it out, [ The crank that is,,,]
