blackhat250
  1. Funny enuff " i just bought a gerry can of Shell V-power, and some leaked in the back of rover, have you ever smelt it ? its nowt like petrol, its more like a chemical factory[ Glaxo near here] so i"v filled all the bikes,,and mix for chainsaws,, as i knew it didn"t have ethonol in it,,, went into garage to-night ,, and that smell is in there now,, took ts250 along the drive and back , it did feel spritely, I know 2 strokes run cooler on higher octane fuels,, so time will tell, As for ethinol,,, lookee here.
  2. Welcome county, as he says, you need reliability for you first ride,,, And $400. for coils ... i"d be needing gold plating for that money..
  3. Sounds like the slide is jammed open,,,,take it out again, or the rubber washer on carb top is missing...to remove pilot jet carb will need removed anyway, a good slotted screwdriver is needed to remove it, as its up a long passage, Wild Foamy will have manual,,, ---Air screw will be 1.5 turns out,,
  4. They"re all similar,,
  5. Yip, when first started = choke jet " then it needs the pilot jet to idle and rev thru the first 1/8 of throttle, then as air speed builds up draws fuel thru main jet ,,,, so get that PILOT jet cleaned, oh i take its got a good flow of gas,[ petcock clear]
  6. blackhat250 replied to Triplespeed's topic in General
    Aye triple" you can get forms " vehicle made from Classic parts" this will get you awa from the Q plate, , inspection will be called for,
  7. Has the float bowls got fuel in them? ,,, beast pull them off , take carbs off and clean pilots etc,,
  8. Its a great read dave, ,, lovely colour the 1G1 model , Our Usa cousins will not have seen them colours,
  9. Welcome criss" start a new thread in workshop section,,, as input in here will get swallowed up with newbee posts,,,
  10. Aye sweetooth" change the plug,, as could be weak spark,,,,if no joy, drain the fuel,,and put in fresh,,,
  11. Bloody ell cynic" that good compression.. Well i got grouched big time,, Zl900 was on ebay,,, sold to guy from Manchester, he came up today,,, its M.o.t -ed. Runnig great all week , idled for 5 mins ,, he takes it for a ride,, i hears it spluttering,,, brings it back - on 3 cylnders,,,fuel pissing out , . so bang goes the sale fuckin four stokes,,,and bang goes my Fazer1000...
  12. Welcome ozy" glad your enjoying the ride,,, gets better in summer,,
  13. blackhat250 replied to matasdad43's topic in The Bar
    Welcome mata"s ,, great bikes ,i thot they were Usa models,,,
  14. Welcome..uwan" i think a dt125 is a tall bike for lads, not a cruiser tho" cruisers are low slung / Lanark show next month ,,
  15. Go foamhe Go" whos has the sissy bar...
  16. Was it a new tube that blew? .. i suppose thats where Tubeless tyres score they don"t go bang, just slow puntures,
  17. blackhat250 replied to jimmy's topic in General
    Aye jimmy" get a electic fence transformer[ sheep fence] screw two long fixings thru door bolt, [ so they protrude inside door] then clip on the terminals of the transformer, [ low setting] leave on all night,,
  18. Welcome maurice" you"l find a download on google.. hows about some
  19. Yeh pat" gotta get out of UK,,, if this weather continues, well be part of the Artic circle....
  20. What do you mean 5 mins " can"t he ride off untill 5 mins ? or it needs choke for 5 mins,,,
  21. Hl" nutter , go to your photobucket album, click on Html , coppied , then paste on your post . if the box appears , click Allow"
  22. Its a 03 Plate pat. in blue. i hope the guy comes good with the bike,,, am awaiting his reply,,,
  23. I bet the selector fork is badly worn or bent, or 2nd gear [ spinning gear] will be needing shimmed, it will have too much side movement, [5mm is too much] as you try to select 2nd" the spinning gear will move away from the driven gear, resulting in a false neutral. also the if bearings on the shafts are worn , this allows side movement also... all them "mm" add up to poor gear selection,,
  24. blackhat250 replied to jimmy's topic in General
    Well done jim" the paints faded on front very quickly. .. yeh diggin deeper mean s retaining walls also
