name that part
Welshie " your head is a Spacer for your ears...
Starter motor stays engaged
Same happened to a Z1000 i had, the rummbling noise sounded like crank bearings, i used thread lock on screws.
New arrival - '77 RD400D bitsa
You got a steal ther mate " and thers a 400 lump 1 mile from me , without barrels & carbs, i will enquire if you need it , he wont sell to others , so no rush
English 101 (for Americans)
Bloody ell me china " your a real Diamond geezer pete,
DT175 G Starting Problems
33-1 was Yam pump Setting, good ,sounds like your near there,
One happy clam
Good on ya bipp" weve got heat up here, no sun but warm air, been out last two nights great, weve not had this weather for 4 years,
FS1E " Northern Rally.
Yeh " you"L both be missed , its the same format as the 2 stroke meet dave " ride-out ,then back to Squires, camping there,
Your on the right tracks " the choke plunger has a rubber washer on the end , it seats down on top of jet tube, when you had it out ,you shudda blasted down thru with carb cleaner, till it came out bottom of the long brass feed plpe, a;so check the rubber on plunger for wear ,
my '09 V Star 950
Some Bling on her "
DT175MX Jetting, Plug Chops and Confusion
Well done paul" you"v a degree in Mixture now , . i had knocking with the TS250, i thot it was detonation, turns out a rebore solved it, i had rebuilt the bottom end, and stuck a N.O.S piston in , on the standard bore,,, but she didna like it,, Am all ready for FS1E run,,, be good to meet up,
me, myself and my bike
Welcome loon" whats it like to ride with ape hangers,, they look awfull, ? i"v seen bikes on the M.way with apes. is it comfy,?,
Hello All (Yamaha Ybr)
Yeh zak" save your money for the big bike, as ad ons sometimes look gash, Bye the way..
Newbie
Hi- jack " ... thers a XJ forum too , the Admin is a member on here,
FS1SE Chopper
Yeh rick " more info helps, its the FS1E Rally at Squires next weekend,,,
Hungry Chicken
- ebay bidding
Ian " make your mind up what you are willing to pay,[ limit] then bang in that amount 2 mins before end, remember to sign in, as you"l not have time to do both , av lost out like that, was watching item- tried to bid - then sign in page appears, dam,,- Hello from a Newbie
Welcome Stu, great intro. its amazing that you"ve taken to the smaller bike after a 1200- Sun, Sea and Sangria
Have a good 1 jim " you"l miss ALL that good weather were to be having,,,- XS 250 for a beginner.
Yip tommy " i got a full box of springs at Staff show, for A tenner, all sizes,- Oh Balls!!!
Yip paul. been haulin every bike to pieces in the last month, i"v rebored the TS250, its so smooth now, Fitted new spring on shifter pawl [behind clutch basket] twice, on H2 , as first 1 was too weak, And had the carbs off the Illiminator that often ,i can do it blindfold now, only to find out its the petcock diaphram thats goosed,- DT175MX Jetting, Plug Chops and Confusion
Wheres that bloody Cynic " i want the conclusion, has he run out of oil AGAIN,,,,- DT175 Running problems
Yip , when lever is pulled in they should be loose. do you have a socket set, start by slacken them 5 bolts, if it turns ,slip a 2p in between them cogs, , and place every plate in order they came out, , clean the steel plates with sand paper, or the like as you install them in order, theyre will be rusted marks on them- My new SV650
Very nice alex " thats a fancy tail light too, kwaker colours tho "- howdy
Wow thats a cool steed bev" welcome bye the way,- DT 125 Tyres?
You look big on that bike , how tall are you. ? Try cats paw, tread pattern,, - ebay bidding
