blackhat250
  1. Am at Blackpool Triples Rally that weekend,,, hope to see some britts riding down from here, I take the A7 -A6 ..friday .
  2. Great story, the video Terra-Circa is brill too . Austin Vince. awesome trip on DR350"s . long before Boorman & Co.
  3. Is my volume fked " or is it quiet... Avitar looks like Guy Fawks
  4. I think you"ve confused the Tailpipe with manifold, unless you"ve a numberplate on front mudgaurd,
  5. Shall we see them in your next video. And the bars
  6. Thats what happens when you have too many bikes, . am offloading the DT125, . got rid of the illiminator in october ,
  7. " all the adjusting to compensate lack of idle, And check your throttle cable . if this is tight , no amount of screw adjustment will help. . back off cable to drop slide . back off idle screw , and start again to find idle,,
  8. Is that skelton hands .or oyster shells...
  9. Yeh" spray behind the flywheel with an excelarent . [ WD/ Brake cleaner/ carb cleaner/ ] while bikes running " if the seal is worn / hard. it will pull excelarent into crankcase, and revs will increase , was the bike unused for a spell , ? The other seal R/H. pulls gear oil thru [ when worn] and smokes heavily,
  10. They remind me of a Honda [ style] 250 in the late 70"s , think it was a single with twin exhaust head.. RS250 maybe,,
  11. Were on the same track DT50 "
  12. Was the idle fine when engine cold, ? how old is this DT
  13. I take it that was the idle screw , you backed off" large knurled edge, not the air screw[ small cross head ] ? As the idle screw just raises and drops the slide. a small amount should not cause engine to die,
  14. Ah" i thot this was the project bike,,,i did think it was mint.....
  15. Bippo" you are Hardcore,
  16. It will be crude, i am 100% shure this is the problem" A drill my be too big. thin wire. ultra sonic would shift it, poke in from the low hole too. this needs to be clear , as fuel passes thu low hole, fills to float level. choke pipe feeds off here, ,,, While blasting [carb or brake cleaner] spray up feed pipe too, while choke lever in open position
  17. Thats tidy" did you get her running, them CDI"s are better remade by Speedshop or west county windings,
  18. Yip" this feeds the choke jet. not the brass pipe in centre, the hole on bowl edge, a pipe [on carb body] drops in there, blast it clean thru, And picture of choke lever is correct for off , when lever lifts it opens choke jet. by means of plunger it connected to.
  19. Hi panicbar" first time av seen a neebee post hi-jacked,,,,like your style...
  20. Yeh" Kev"s a bottomfeeder Land scaper. i mean, Foamy" you"l find the pub going females are all nutters, just watch that vally"s or geordie shore, And i married one , and most after that were the same, am afraid its the type you attract mate...
  21. Look same as Garelli tiger filtre. "
  22. Am thinking dirt in fuel tank, as it ran well for short time, now carb could be choked again . run fuel into CLEAN container
  23. Yeh" but the coil may breakdown once hot, lets try the simples first tho..
  24. Pull the fuel pipe [ tank] run it into a jug. see if flow is interupted.
  25. Well done hichy" its a learning curve, hope she rides well now,,
