blackhat250
  1. Hi stuart " the biggest difference is the YZ /MX is about 30 bhp , [ bigger carb and big porting ] front forks will be bigger also diameter & lenth .
  2. Possibly a restricted model, with the gubins removed,,
  3. Hi frank " another V70 owner lately ,,
  4. Aye ski " Enduro bikes were basic , as they were gonna get dropped, no fineries on the IT"s ,, what you got was a ported motor, DT175 15BHP - iT175 23BHP, bigger carb too ,
  5. Capt " the MT07 is great [ check write ups] cheap too, The old Fazer600 , are cool , And the Triumph street675, [ daytona frame] best handling ever, If I buy a new bike , [ havn"t since 1976] it will be either a Yamaha Tracer, OR 800 Tiger XR
  6. if you pull the clutch in does it quieten ,?
  7. Bugger slice ", big bikes are a hand full, thers no stopping them , Tasky " you were lucky,, saved the TANK " ,[ as dt50 used to say ] , Am woking on the DT at the moment, I can pull it and the bike hoyst around,,,[ 120kg]
  8. Early Kawasaki"s were like that, used to rev theyre nuts of when on choke,[ great way to fk the cams, oil slow to reach them ] I think your too lean , [ mixture]
  9. Hi vario " , your the bikers of the future, you sound keen too...
  10. Just watch and not shear the exhaust studs, on older bikes plenty penetrating oil days before the job, or it may turn into a big job, [ head off to drill out studs, ]
  11. Hi zul " whats a low jack ? and damper, new battery will solve starting ,,etc, Is there an alarm on it,,, these kill batteries
  12. If its valve clearance , it will be hot start that be the prob,. that pilot jet is blocked, as soon as choke is off , pilot jets does first 1/8 throttle then venture speed brings in the neddle jet, then main when on Wide open throttle,, By all means check the clearance tho ,,it all helps the running,,
  13. She should fire if everthin is good, summats up spur, re-check spark and timing , as your getting fuel,,
  14. Hi puddle " , better fit a lever, as braking to a stop will result in a stall, shes a heavy bus too,,,reliable too
  15. That's a bugger spur,,, jump it from a car battery,
  16. I like that tommo" , check out u-tube spaying tips ,,,and go for it
  17. Yeh " if you have an incident, [ argument or gestulate ] with a driver, it effects you for a while, don't dwell on it tho,
  18. Hi rhys " your an old newbee then ,,,
  19. I saw show on Motor TV, [ the bike show] looked a good show,,, Scottish show on the 7/8th march , will be there,,,
  20. Them are cool wheels , red hubs or rims,,
  21. Be seal on 2 stroke pump, filling the gearbox,,, on a ????????????????? Edit" I see you"ve posted this exact thread on the DT FORUM, so it be a DT 125 ? DTR ?
  22. Ok " so its fuel then ,,,whats the carb like,,,and is there fresh fuel in tank,
  23. [ Quote kevthe rev , rule out big end ] So was I kev "
  24. " Bang " Explain
  25. At least we know its not the engine , as kev says thru the footpegs, = sprockets or chain, My tiger did this on over-run last year, it turned out front sprocket was hooked teeth,,
