xmastree
Supporter
Everything posted by xmastree
  1. xmastree replied to kev's topic in The Bar
    And?????
  2. Oh yeah?
  3. xmastree posted a topic in The Bar
    I saw this and thought of you...
  4. xmastree replied to Bello's topic in The Bar
    So long as the post can be read before payment is made... A link on the 'you need to pay' page would probably be the best solution.
  5. xmastree replied to The Dude's topic in Yamaha Gallery
    Ahh, but she's not my sister... Nice bike, and I think you were right to remove the stickers from the swingarm.
  6. Got it back yesterday... Not bad for £30, and a hell of a lot better than one of those DIY covers which cost £25 and end up looking like a sack of potatoes. He does mail order (the address is Bradley Mills road) but it's worth a trip there just to see the gorgeous Triumph flat tracker he has in there.
  7. xmastree replied to Bello's topic in The Bar
    So why did I just have to pay £2.00 then? I don't object, after all it's a pittance for a lifetime membership, but having read this previously I was surprised that I now had to pay. An email explaining the situation would have been nice..
  8. And so I did. Took a run over there today and dropped the seat off. It should be ready for collection on Saturday. I'll post pictures of the finished seat. Cost, £30 for a standard re-cover.
  9. Take a look at this thread: http://www.yamahaclub.com/forums/index.php?showtopic=6816 There's a recommendation there for an upholsterer in Huddersfield who could probably do something for you.
  10. How are you charging the battery? If it's with a separate charger, try disconnecting the battery from the bike before charging it. Then leave it off for a day and see if it still has the charge. If it does, then there's something on the bike draining it. Is there an alarm fitted?
  11. What's wrong with that then? Looks a damn site better than mine ATM. (I'll post a pic soon...) Huddersfield, eh? Might take mine along there.
  12. xmastree replied to philyam's topic in Classics
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=170126637445 Better be quick though, it finishes tomorrow evening. PM on the way, just to be sure.
  13. xmastree replied to ndickey's topic in Yamaha Workshop
    Can I jump in here? Mine drains all the oil when I remove the left hand cover to access the timing disc. Is this normal for the DOHC version?
  14. xmastree replied to kev's topic in The Bar
    Can't see any post by kchops (in fact there's no such user) in the gallery... Got a link?
  15. Nope, the lobe should point directly opposite to the valve. So in that photo it would point towards the camera.
  16. No, the tappet won't come up any further once the valve is fully closed. And if there is already a gap, it will just get bigger. However, having just had a proper look at your photo, do you realise you haven't rotated the camshaft far enough? The lobe ought to be pointing away from the tappet. Yours is only 90 degrees. I suspect you've only turned the crankshaft 180° when you should have turned the camshaft 180°. As you have the tool, I'd be tempted to try again, but make sure you turn the cam far enough. First turn the tappet so you can see the small slot. Then fit the tool with the valve fully open, turn the crankshaft one complete revolution, this will turn the camshaft 180°. The shim will be stuck to the tappet, so you need to push a small screwdriver into the slot to dislodge it.
  17. I didn't use the tool for mine, I loosened the camshafts a little and lifted them. A strong magnet is useful too. rotate the tappet until you can see the small slot, insert a small screwdriver and get it under the shim. It will be 'stuck' down, but they do lift up. Once lifted you can draw it out with the magnet. As for the gaps, intake is .004 - .006, exhaust is .006 - .008
  18. I found this while looking for stuff. The main jets are 132.5 (German spec) but it has the screws you need.
  19. Yep, they have the size stamped on them. You can see it if you look real closely. You don't need to remove them to see the markings. See this pic for an idea. According to my manual, the left one should be 127.5 and the right 117.5 or for the German model 132.5 / 130
  20. That yellowish film may also be partly blocking the jets in there. I would buy some card cleaning fluid and make sure they're clear. Do not be tempted to use wire or anything to poke through the jets, this can enlarge them. If you remove the jets, keep the bits separate as believe it or not, the left and right use different ones.
  21. They do look clean, but it's the inside which is important. Remove the four screws holding the bottom on and look in there. Hopefully they won't be like mine were...
  22. Because it may well be intact on the original post. If you post a long link to a forum, it gets shortened for display. Copying and pasting the text doesn't copy the entire link. like this: http://this.is.a.very.long.link.which.does....prove.my.point http://this.is.a.very.long.link.which.doesnt.really.go.anywhere.at.all.but.ought.to.prove.my.point See the difference? (and that cut is perfectly placed...)
  23. Thanks for that, but could you go back to where you got it from and get the full link please?
  24. One of these? I fitted this type which is mesh rather than paper (and it only cost me £1 from the local bike shop...) The one cylinder thing, I think, was due to a blockage not in the pilot jet but in that hole in the bottom of the float bowl which comes up the side IYKWIM. At the top in this picture, next to the big alloy circle thing. (that was when I first got it, not just now) I think that feeds the choke (via the brass tube visible above the right side one in that picture), so it would seriously affect cold starting. I got a syringe full of fuel and forced it through the hole. It was much better after that, but if I don't get a decent filter I'll have to do it all again soon...
  25. I need a decent inline fuel filter. I stripped the carbs, and the float bowls were full of muck. When I had them apart before I had them ultrasonically cleaned. I guess the crap is coming from the tank. I already have a filter in the line, but it obviously isn't doing its job. Any suggestions for an effective one?
