delmsie
  1. Some progress. The view from my kitchen. It forces me to tinker. I'd hate to think this air line was some award winning design feature. It was a nightmare to deal with. But there is probably worse to come in this project yet. Finally got the forks out. It was a slow job for amateur me. I think the fork oil was the original it was manky and black. I can't believe the amount of wiring stuffed inside the headlight. I reckon I'll have to pull the triple tree off and check the bearings as everything else is rubbish it might be wise to check them out. I have decided to black the front end out. Most of the chrome is shot so a major clean and antirust treatment and a paint looks the way to go. Gauges have to go too.
  2. Right, I had gotten complacent and overwhelmed with this project. So it has sat idle for months while I blamed an illness for not getting on with things. In an effort to solve this problem I have now relocated the bike to my verandah. It now sits right outside my kitchen window and forces me to do some work on it. Strangely it seems to be working. I am now slowly pulling the forks down. Now I just have to work out how to disconnect the air line in the forks and remove the forks. I had to buy a Hex socket set to remove/loosed the fork caps. I am glad the decent one were on special. As thing things were so tight some rubbish ones would have destroyed the part I was working on. Handle bar problem solve with Z bars. A lot more expensive than the flat bar but a noticeable increase in quality and the size is exact not approximate like the cheaper ones. Now to see if I can keep the job progressing.
  3. Thanks for the feedback Airhead. I have switched to Photobucket for a try see how the photos go now. I just had a quick fit of the new bars and they are too low and the controls hit the tank. The other bit I wasn't happy with was the cables are all very cramped and bordering on getting kinked. I did spot a set of T bars with a 4 inch riser at an Australian eBay site so they are looking like plan B. Looking at the photos I just took I realise now just how much some of the parts need a good clean up. The bike wheels off for tires and paint. Darn the tank is in the road. How rubbish do those controls look? They don't look as bad in the flesh. The chunk I had to cut out of the exhaust to remove the axel. A fresh new look. I also managed to improve a few dents on the tank with a "Pops a Dent" tool. Hot tip turn the handle with a rag as when it pops off to can take a chunk out of your finger. It worked reasonably well and got about 80% of the small dent gone. Okay Photobucket you rock. Those photos are a big improvement. The attempt at flat bars.
  4. I swear I am doomed. This is my 4th attempt at getting something up here and I have internet,forum and possibly mental melt downs. I have been pretty slack as far as work to the bike goes. The weather has been great and the bike fun to ride. But the forks have leaked all of the oil rendering the bike pretty unsafe to ride. Forcing the issue of getting on with the job. I have decided to not paint the bike but to use plastic wrap. So it will be interesting to see if that was a good or bad idea. So a few photos and a random solar eclipse shot taken from my driveway. Finally registered and on thew road. As far as I had to pull it down to get the roadworthy work done. Before paint and tire. Solar Eclipse taken from my driveway. Now I understand what all the fuss about a total eclipse is all about. It was pretty awesome. Paint and tire. I finally got it to work.
  5. Okay I'll get some pics up over the weekend. She is pretty ordinary but mobile at the moment. New bits and pieces have arrived this week so the rough pull down and assembly will have to start soon. I'd better clear a space on the verandah to do this. But this bike sure is thirsty 137k to a full tank. Mind you I don'y think anyone has paid any attention to it for years.
  6. Finally an update. New front and rear tires and battery fitted. What blew my mind was that the bike started brilliantly with the new battery. Better than it did from the car battery directly wired to the cables. I decided to spend some time and give it a cosmetic clean up. I used some flash proprietary cleaners and a mop spun by a drill. The results were okay but tedious. I later tried some fine pumice and a wet rag. The difference was amazing the pumice cut through surface rust and other gunge simply and easily. The bike now looked not to shabby anymore. I decided to push my luck and booked it in for a Safety Certificate to find out what work it needed done to it so I could register it. Blow me down 1 split pin was all I needed. It is now registered and I have done a few hundred K's on her. The motor is brilliant and aside from some noises from the front discs (I think) I am impressed. After riding it for a few days and then jumping back on my XVS 650 the comparison is interesting. The 650 has a much nicer feel it. The difference in the handlebars I believe account for this. the 1100 is much more powerful (funny that) as way smoother in acceleration. The clutch and gear changing on the 1100 are pretty hard in comparison. I must add I really do like the toe and heel shifter on the 650. New bars,indicators,tail light and fender are on order. I'll have a crack at fabricating my own saddle after I sort the fender out. Pretty pleased with the outcome thus far. Direct costs $1160.41 Incidentals $304.75 Total $1465.16 on the road. I'll add in the extra parts once they arrive.
  7. Oh fun times. Made headway on the front wheel all ready to paint and masked up. Got excited about the way the bike was balancing nicely on some bricks and the centre stand and decided to attack the rear as well. Checked out a few YouTube clips "removing the real wheel" etc. Okay a 6 minute job for them so I figure a hour for me. Wrong. Steadily making some headway and I can't get the axle out as the exhaust is in the way. <a href="http://imageshack.us/photo/my-images/197/img0546u.jpg/" target="_blank"><img src="http://imageshack.us/a/img197/5083/img0546u.th.jpg" border="0"/></a> <a href="http://imageshack.us/photo/my-images/811/img0544db.jpg/" target="_blank"><img src="http://imageshack.us/a/img811/5038/img0544db.th.jpg" border="0"/></a> Grrrrrr no mention of that anywhere. I consult the workshop book on exhaust removal and it looks to me like the centre stand will be in the road when its down. So I even try jacking the exhaust up with a floorjack. Nope it doesn't move but not the bike is balance on one leg of the centre stand and a brick under the motor. It is about at this time I decide that it is time like this why the angle grinder way invented. So in a fit of frustration the exhaust way cut away a bit to allow the axle out. More than one way to skin a cat. I also discovered in this whole process the wheel bearings are dead and rest brakes are in need of replacing. So I will be smart and get them replaced at the shop when they fit the new tyres. Direct costs $736.46 Incidentals $251.85 total = $988.31
  8. I cut up a picture of the bike, removing the bits I didn't want. Bars,gauges , rear fender and cut the seat in down to an ideal size and it looks better already. I removed the front wheel tonight to have the tire removed (it's cactus). Before the new tire is fitted I'll clean and paint the rim. I imagine that this will be the easiest way to do this minus brake discs and other bits and pieces to get in the road. Looks like I'll polish the smooth parts of the rim and paint the rougher as they would be a shocker to polish.
  9. Nice tips both of those. I'll give the photocopy method a shot over the next week or so. It's got to be better to have some sort of plan than just attack it adhoc.
  10. Why not. I'll give that a try too. I also saw one lad poke in a flexicuff. (Blood pressure monitor) into the tank and inflate that to give pressure from the inside. If all else fails there is always good old bog and sandpaper. I checked out those Acewell instruments and I think that they will be the go. Not too expensive and everything is there. Did you have much trouble doing the install of it. Does the Taco work okay with the twin motor? I have looked at so many bike and got so many ideas jumping around in my head it's nuts. But at the end of the day I think I'll keep it all pretty simple. That said I hope it doesn't come back and bite me.
  11. Tried to remove a small dent from the tank using an idea I saw on YouTube. Hot air gun then cool with a can of compressed air. Spent nearly 2 hours running all over town to find a can of compressed air. Wow $15.90 for a can of nothing really. It's twice as expensive as WD40 and made by them as well. Okay fast forward it was a fun experiment and as I expected it failed. I reckon the tank is a bit thick for this method. PS don't touch the frost to see how cold it is it's really cold. My finger is still sore. Total so far $798.20
  12. Yes Campaman I think I got lucky. The receipts are in the bin Noise. Did this nonsense with a bicycle I got for $5.00 and nearly $2000.00 later it was finished. Nice bike though. Cost so far Motorbike $500.00 (I got lucky) About 321 pound Oil,plugs and filters $ 53.00 Incidentals to the job. New tools and odds and ends needed to do the work. $229.60 most of which will be around for years to come. All up so far $782.60 or 504 GBP Uploaded with ImageShack.us Meanwhile this is the daily ride.
  13. Hi Mark, That sure looks like it was a great buy. Enjoy!
  14. Done project thread started!
  15. I set off to buy a scooter 12 months ago and came home with a new XVS Classic 650. Amazing what some great service at a dealer to do for you. Then I discover that there were plenty of other interesting styles of bike out there that got me salivating. I am more a cruiser that a racer type of guy. With that in mind I have kept my eye open for a suitable donor bike for a project. One popped up several week ago a few hours out of town. It took a couple of weeks to arrange the trip to look at the bike and I liked what I saw had potential and bingo offer accepted and I got to drag home my donor bike. The Virago 1100 had sat somewhat exposed to the elements for the last 2 to 3 years apparently. It was pretty grotty lots of surface rust and 2 flat tyres the front was split form being so flat. So she was a big gamble for me. It wasn't till after I had the bike home I discover that this model doesn't have a normal style frame and the motor is suspended. My heart sunk a lot. Jumping back on to Google and Youtube I found a few images of successful projects and got a excited about the project again. Today I'll have to call day 1. Now I am more at home with a bicycle than a motorcycle. My mechanical knowledge and aptitude is about zero. But I do have a few friends who are a font of knowledge to tap into. I spent the last few days of pumping them for info and securing a workshop manual for the bike. So armed with my new found knowledge and a battered book I had a crack at resurrecting the bike. I drained the fuel from the tank and carby's,popped off the air filter, dropped and replaced the oil. Squirted some oil into the pots. (squirted WD40 in a few days earlier too) Tossed the battery its cactus and wired it up to my car and turned it over a few times. So far so good. Put in some fresh fuel (stolen from my lawn mower) 2 new spark plugs then shot some "Start Ya Bastard"(yes that's it's real name) in its lungs hit the switch and after a cough and a splutter she roared back to life. A little happy dance followed believe me. Then lots of call to thank the mates. Now secure in the knowledge that it's a goer I'll have to find a space to work on her. The immediate plan is to clean it up and get a roadworthy certificate and registration. Then I'll pull it down and start the renovations. I think it will be easier to appease the powers that be that way. The bike will be a BOB of some kind or some weird genetic freak. I have assembled ideas from a multitude of bikes and will try to blend them into this bike. So It may be acceptable or absolute garbage only time will tell. But at least it goes.Sounds okay too! I'll formulate the ideas for the project and post them here soon. Plus I think I'll also post the costings of everything and a total so far. That could be interesting or depressing seeing where the money goes.
