gemini
Everything posted by gemini
  1. red hot water, goes on easy and doesnt move once its cooled
  2. Even when warmed up the air screw has no effect when turning in (even closed) . this is due to the pilot jet size, float height wont affect it, but main jet size does slightly, better to start of with the standard jets and go from there
  3. shame you didnt reply to none of my pm's, i was going to bring you a carb to try as its nothing to do with the electrics
  4. good link, thanks
  5. gemini replied to splittie65's topic in Classics
    just take the cover off and have a look, the electric start 125 does have one, yours may not
  6. gemini replied to splittie65's topic in Classics
    easiest way is to take the head off and use a feeler gauge and a straight edge, this is the only way to get an accurate reading as the piston is domed on top and the plug is on one side, the advance should be held open when you set the points, a cotter pin spread apart works well to hold it open
  7. not sure if Cynic forgot the link but its here http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php
  8. http://www.yamahamotorcyclespares.co.uk/spares/partImage.asp?GPN=Z%3AO%5D68%3A%3D%3B5555&uid=0
  9. the bike will start while on the stand, it will cut out if you put it in gear while the stand is down
  10. mixture screw is here, there should be a black rubber bung covering it
  11. did you do a compression check on both cylinders before you stripped it
  12. have a look here http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?ModelID=9738&pageID=3&m=YAMAHA+XVS125+2002+CRANKSHAFT%2E+PISTON&uid=0
  13. you will need a 17.5 pilot jet, the standard one is a 15
  14. could be just overtight
  15. slick 50 was made for worn engines
  16. why are you asking this again?? phildawson kindly posted you a link how to check it in your other thread
  17. "Had to bump start it to get it home" that itself says the spark plugs are ok, you say its not turning the engine over, do you hear a clicking sound? first check the battery, make sure its charging, if its ok its probably the starter relay, if the battery is ok but not charging its the rectifier mods, this could do with moving to the workshop
  18. the needle is under the Vacuum chamber cover, 4 screws top of the carb, tbh i wouldnt run the engine with the rubber restrictor removed without a bigger main jet in, but saying that it wont run anyway above 1/4 throttle, you havent said if you have actually tested it first speed wise if thats what you are trying to achieve, if you havent you wont know if you have made it better or worse, have you done a compression test on both cylinders?
  19. toned down the fuel pump a bit?????
  20. Air-cooled, 4-stroke, SOHC, yes it has cams and chains
  21. if they are crosshead plastic screws the originals have been replaced, just take the screw out and the plastic clip will pull out
  22. providing they are original, push the centre pin in, pull the clip out, you can get to the bottom of the carb by removing all the air filter
  23. carb is a mikuni BDS26, standard main jet size is 90, thread is 5mm, i thought they were 6mm diameter not 8mm like this http://www.ebay.co.u...=item43a6ea21a5
  24. sorry, i meant to put 16, 18t front 59t rear makes the gearing 3.28
