Posts
6,926 -
Joined
Last visited
Days Won
72
Content Type
Profiles
Gallery
Yamaha Racing News.
Media Demo
Store
Collections
Classifieds
Everything posted by DirtyDT
I got swine flu and now I am as happy as a pig in s**t. And tax free.................. so far!
Cheers. I have taken the cover off and there was some 2 stroke oil in the bottom of the case. I have cleaned it all out and made sure that I could undo the bled screw, which was fine. So I will do what you suggested and open the cable manually. I can also check for 2 stroke leaks at the same time. I will kick the bike over a few times with the spark plug out and the throttle fully open to get the 2 stroke as close to the carb as possible. There is no fuel in it so this will also prime the carb for petrol. I can use an old plug in case it floods as I brought a new one today. That you for the advice. I have just been out and kicked the bike over. Now that I have cleaned the terminals and earths I got a nice fat spark at the plug. Well happy
"The reason I got married in white was so I matched all of the other kitchen appliances."
Hi Cynic, My aim is to put it back on the road as a street legal bike. I have the logbook which shows the reg number. There is no ignition or front lights and no silencer. The tyres are "not for highway use" and no horn, chain guard/tensioner nor clocks. The frame has been drilled about 2 inches back from the hole which holds the front of the shock in the frame. I guess that this was to raise the bike but the original hole is there so that is an easy job. and this is what I know so far looking at it for the first time.. The frame and engine numbers match and there seems to be a good compression. A nice labour of love but first things first so I will check the spark tonight, get the 2 stroke oil bled through tomorrow and get the tank connected to the carb and see if it runs. Gulp
Oh yes!! I am keen to start it but need to check everything on the bike first. Thanks
Thanks for this. The kill switch was connected but I have disconnected that. I have cleaned up all of the connections to the CDI (the CDI was not connected when I got it) and earths that I need and with a new plug and it sounds like I have a spark. There is no 2 stroke oil in it or fuel pipe so I will need to get these. I may have to wait until it gets dark and then kick it over with the plug out but earthed to see if I am right about the spark. Thanks for the information so far. I sent my other half and her kids off to the pictures so I can get some time with the bike. I only brought it yesterday and love it. Non starter and rough as old boots or not. Cheers but I am sure that I will be asking more questions in the future. Bad wiring pictures below
By butchered I mean that the bike has been used off road and no battery no, presumibly a total loss system? There is no headlight and a lot of the wiring is connected by connector blocks. The frame starts 2k4 (The frame and engine numbers are matching) As per the picture I have Green, Yellow, Brown, Red/White and Black coming from the Mag. The orange appears to run to the CDI which has 2 sets of 3 wires. Brown, Black and White/Red and Orange, Black/White and Black. The Orange wire appears to go to the coil which has 1 LV wire. If I put a 6v tester to the mag and earth and kick over there is power from the mag from the Brown wire. The rest appear not to be producing power but this may be down to a bad connection. I cant really test for a spark as I need to shhot out to get a spark plug spanner as I don't have one but should I be getting any juice from anything but the brown? Thanks
I do have the 6 wires from the CDI bunched into 2 sets of 3. All I need now is to work out what I need to connect as the wiring is butchered.
The one I brought today has a 5 wire also I have just posted in another thread to see if someone can help me out with the wiring.
Hi, This is my first post so nice to meet you all. I need some help with a DT175mx (I think. 1981 and the frame starts with2k4). The bike has no battery and someone has wired it so it runs with a total loss system. I have seen some online wiring diagrams however my bike seems to have more wires than the diagrams. The wires from the crank look like this The coil looks like this and the CDI (I dont know if this is right). looks like this I would assume that the green wire from the crank goes to the coil but what about earths etc??? Thanks.
