DirtyDT
Everything posted by DirtyDT
  1. Is this any good?? Here
  2. I think the bike was owned by a gorilla. Not a problem as it add's to the frustration fun! I have been looking for an old trails bike with a log book (V5) for ages. I even looked at BSA trials but too much dosh. Trust me building and working out what goes where (with forum help) is great, loads of grins even when you hit problems. When you have done what you wanted the satisfaction is huge. But, and it is a big but, it eats cash. As soon as you discover you need to replace something and order it, there is something behind it that needs replacing as well. I have spent £300 this week alone and it did not buy much. Mind you it did include a new full exhaust which is somewhere in the post.
  3. Hi OG, I did the old trick of making a groove with a flat head screwdriver and then using the groove to hit the screws around, this morning. a couple of days of WD and as soon as they had moved a quarter turn I gave them loads more WD. They are out now and will be replaced with Allen key stainless. I have wd'ed the threads in the casing and ran a bolt in to spread the lube. The casing is still on the bike at the moment. I have seen TY on Hbay but have not ordered anything from them at the moment. They are not too far from me. Apparently there is a place in Loughborough where they will match individual bolts etc. My mate gets his stuff there for his Thundercat. I am thinking of buying a mixed Stainless Allen type pack from Hbay as a start. I have made sure the casing allen key's all a free, which they are but the sump plug is seezed on. 2 days of WD so far. My other half seems to have hidden my long breaker bar so I have ordered another. As for the original bolts on the oil pump, 2 pictures below. Take a look at the pump bleed screw which is still fitted to the pump. I had to use mole grips to undo this when I primed the pump. I think I should change this also
  4. Thanks OG. I have been heavy on the WD40, tapping the screws and am going to heat today. They will come off!
  5. Cheers Cynic, I have WD40'ed the sump plug and will change the oil anyway. I have a new gasket set in the post somewhere. I don't want to start it not knowing how long the oil has been in there (It looks fresh) and not being sure that the 2 stroke oil is getting through. Have ordered the new oil pipes so they should be in the post too. Cheers
  6. DirtyDT replied to kevin10529's topic in The Bar
    Hagons are good. Not a very good website but lots of stuff and knowledge. I think they had a shop in Leytonstone (E London) about 15 years back. Hagons
  7. Try here
  8. I would just ride it normally (at any revs). Just don't labour the engine and keep changing the oil. That is what I do but possibly not the best advice.
  9. He should have let the bike do a fast lap on its own and mounted up when it came around the circut again.
  10. Hi all, Sorry but I am trying to pick the experts brains again on the forum. Can I remove the oil pump side crank case without removing the oil pump? The oil pump screws are k*acke*d big time but so is the pipe from the pump to the carb. (The pipe that goes into the pressed in joint on the crank case) so I need to change this. My postman has been busy delivering parts for the bike but I have only started it for 15 second (brought it as a non runner) and have never ridden it since I have owned it. I would like to make sure that it starts and runs ok so I can tick some jobs off my list. It will be total rebuild eventually but not to original spec. It has not helped that it was brought not running with a leaking petrol tank, half an exhaust which didn't quite fit, an airbox which came in a box of parts with a knackered older style air filter, a blocked carb with a bent jet needle, and knackered electrics. I love it.
  11. Cheers OG & Cynic, It is a 4J4. The ID No is 3U500. What I thought said MJ6 on the Jet needle is 4J6 The Siriusconinc site is down at the moment but they did not have a huge selection. 4 types and one of those was sold out so I could not see the specs. I think cms have some individual parts but not the Jet needle. I found one here Here Addition If C$ then about £4.50 plus postage I would still prefer a set though
  12. It does seem so. the benefit of the buy one get one free is there are still plenty about. I emailed siriusconinc and they came straight back $19 plus $7.5 for postage. That is about £17.50 still a bargain but damn the weak pound
  13. Thanks OG. I did not know that JimR. Mine is registered in March 81 but not the first. I do remember the times when the law changed. I had a Suzuki250 GT on L plates around then. NRP seem to be the supplier of Keyster in the UK but there site is not too good. I have emailed them but if not I guess that I will have to buy from abroad. Cheers
  14. Hi All, I have been stripping more off the bike today and am going to refurb the carb. Searching through earlier threads I understand that the carb on these is a VM24ss. Are there any refurb kits available for this? There are some specs in earlier threads re the jets, float height and needle position but could someone please confirm what the UK specs are for this year. I have not got as far as taking the carb apart yet as the needle is bent. I can't read the writing on it as it is worn but it looks like mj6. The circlip is in the 4th notch from the bottom. I obviously need one of these. Any advise on where I can order the parts for this. I have looked at cmsnl but am not sure which model I should be looking at and if the European specs are the same. Cheers
  15. DirtyDT replied to mervin's topic in The Bar
    Oh yes... been there
  16. DirtyDT replied to awxjr's topic in Yamabyss
    Fantastic Put a hot soldering iron on the bolt for a while and crack it off. Some people semi tighten the bolt first to break the lock. Only heat well do - in my opinion. Then drink the Stella.
  17. I decided to get a pack of 3 for the weekend so I got these In case it rains I thought I would try and cheer things up a little. A piece of tarmac is standing at the bar chatting up twin zebra crossing signs. He is boasting how tough he is. “I am the toughest road in the world” he says. “Everyone is scared of me” The twin zebra crossing signs giggle. “Cyclists, car drivers and truckers are all scared” he says. “I even scare Yamaha riders” At this stage the girls are getting a bit wet. The next minute the doors of the pub are kicked open and a slab of red tarmac walks in. The red tarmac shouts “I am the toughest thing in the world”. The loud mouth piece of tarmac cowers, looks the other way and shuts his mouth. Red tarmac strides to the bar and orders a pint. He downs it in one and walks out. The Twin signs turn to him and say “If you’re so tough why didn’t you take on the red tarmac?” He replies “You must be joking………………………He’s a cycle path” A gorilla walks into a pub. “A pint of beer please landlord” says the gorilla. The barman pulls the pint and thinks….Hmmm he’s only a gorilla……”That will be £30 please” As the gorilla supps the pint the barman say’s “we don’t get many gorilla’s in here. The gorilla replies ………………………………………. “At £30 a pint, I’m not surprised”
  18. I don't remember. It was some seedy soho club. downstairs to the venue. I guess that someone paid a lot to get GH there. Alex Harvey was ace. People say about Freddie Mercury was a showman but AH was the man.
  19. Doctor
  20. I remember them all. V sexy women. Good old Steed was class too. I was watching one the other day with JL in. Oops, a sudden rush of blood to my loins then. They show them on one of the "old" channels on cable. Along with Minder, The Professionals, Sweeney etc. I love them all. I also remember Gareth Hunt. He was the male side kick in the "new" version. Famed for his hand movements in a coffee ad. Did you know he released a record? I went to a bar in Soho many, many, moons ago to watch the Sensational Alex Harvey Band and Gareth Hunt come on and sang his record. I don't remember anything about it but it was sh*te Anyway. I can't afford my own porn, why should I pay for someone else's? If I robbed a bank and got caught and said it was a mistake and I will pay some of the money back would I get prosecuted?
  21. The call them nun's because they don't get any!
  22. A young nun in a nunnery wakes up one morning and finds hair growing between her legs. Being innocent she and not knowing about puberty she runs from her cell and looks for mother superior. On her way she meets father Abraham. “Father…. Father” she says, “Where can I find mother superior?”. “she has gone to town for the whole day” the priest replies. Seeing the nun is distressed he says to her “You look very worried tell me what is the matter and I will try to help”. The nun is very embarrassed but after a little coaching she tells him she what has happened. “Come into my cell and show me” says the priest. So they go into the priest’s cell and she lifts her habit and shows him the hair growth. “Don’t worry” the priest tells the nun “that is normal”. The nun is still looking worried so the priest says he will lift his habit to show the nun that hair is normal. The priest lifts his habit and exposes his hair and cock. “Ah” Says the nun. “I feel much better now that I have seen that you have hair there but I have a question” Pointing to the priests cock she asks “When will I have one of them between my legs”? The priest replies ……………………………………………….“As soon as you lay on my bed”
