paulmould
Everything posted by paulmould
  1. Have looked for a reaer light and number plate assembly small but not going to draw attention to it, does anyone know where i can get one from ??
  2. Thanks, i have a new set of gears to put in, will be a first for me will keep my fingers crossed most likely to have 6 reverse gears after i try.
  3. paulmould replied to blackie's topic in Yamaha Workshop
    My DT 125R has the same leaky gear selector seal, but i recon the previous owner ran it without oil and i have a knocking in first gear, not too bad its gone in second, but does anyone know why it knocks ?? is it the bush or bearing that holds the gears on the gear box casing gone and its rubbing under the pressure of first gear. Paul
  4. I get the same it looks like a spyware redirector, i will try and detect it and let you know. Paul
  5. I have a 1998 DT 125 R its a good runner and starts no prob, but in 1st gear it makes a nockin noise, it almost sounds like its under tention, but when you go into second or any other gear it runs as sweet as a nut. Can anyone help with a poss problem ?? Paul
  6. I have a 1998 DT 125 R its a good runner and starts no prob, but in 1st gear it makes a nockin noise, it almost sounds like its under tention, but when you go into second or any other gear it runs as sweet as a nut. Can anyone help with a poss problem ?? Paul
