drewpy
Everything posted by drewpy
  1. drewpy replied to jumpwin's topic in Classics
    sounds like the swing arm bushes have gone, you can check by the sideways play on the swingarm 1mm max (is on my xs400) the electrics on those bike had a reputation along with the cam chain. I agree that they are great looking bikes, the 850 was the updated 750 with all the niggles sorted. have a trail through the old forum via the search system as I'm sure that someone has asked the same question. BTW check the middle gear box oil as that gets forgotten at service times!!
  2. drewpy replied to apathetic's topic in Classics
    If the vaccum gauges do flutter, there is a knurled knob on the pipe which needs tightening up till the fluttering stops. this acts as a damper due to the engine characteristics and is normal on all bikes. checking my manual, the carbs are the same as the 400 but have different sized jets, so you need to ask them for a 360 kit. the 360 has; 135 mains, 0.6 air jet, 4FP21-3 jet needle, X-6 needle jet, needle position 3, pilot jet 17.5, starter jet 40. air screw 1 to 1.5 turns out from stop. send them an email, as they have tons of stock. if they don't have any try NRP in Manchester UK!
  3. drewpy replied to apathetic's topic in Classics
    Those are the carb kits, in fact the exact same ones I bought. Don't forget you need two! The valves are really easy, just use your manual to set the crank to the timing marks and 10mm spanner and feeler gauge. rtv on the inlets is not a good idea, use a gasket and check rubbers for cracks/splits
  4. drewpy replied to apathetic's topic in Classics
    WOW some text 1) Sounds like air is getting into the inlet side of the bike. Spray some wd40 around inlets and listen for any engine revs which would iindicate a leak there 2) you need to get a keyster carb kit and replace everything with the kit 3) tune the bike by setting the valves, points gap, timing and finally balance the carbs. If you get the vaccum guages there will be instructions in there. you need to find a way of supplying fuel with the tank off the bike and you use the stubs on the inlet rubbers as vaccum take-off. hope this helps
  5. I assume your talking about the 2A2 engine, as there was a later dohc engine which won't fit. the xs400 will slot straight in and is in fact lighter than the 250 (bigger bores I assume) you can't just overbore as the valves are a lot smaller and uses a different carb 32mm-250 34mm-400. I think even getting a 400 barrel onto a 250 bottom end could cause the liner to foul the crankcase mouths (not tried it, but i'm guessing) I bought a 400 engine off ebay for £50 and carbs for £20, then you need the rubber between each side of the carbs for the bigger mouths. Well worth the hassle though as mine motors up to 85 and great on the twisties. a custom model will fit as its only got a rounded barrel as opposed to a squared off one. Be careful of the 12n model as they have "rear sets" which If yours hasn't then you need to figure this into your equation. BTW loads of stuff in germany, but be carefull with carbs and camshafts as they have restricted (27bp) engines drewpy
  6. 23
    drewpy replied to Section 8's topic in Yamaha Gallery
    I'm thinking; Flying time and CAT B write off
  7. drewpy replied to DOUG's topic in Classics
    Go for it, if you like the bike its gotta be worth it. over 15 years old is considered a classic nowerdays!!
  8. drewpy replied to Jonners's topic in Classics
    Have you tried ultrasonic cleaning? I used JRS and cost £100 for a pair to clean.
  9. quickens the steering at the expense of high speed stability
  10. drewpy replied to kev's topic in General
    its the union flag not union jack.
  11. don't fortget to break the seal first on the rim. I run my car over the tire slightly and you can hear it crack. otherwise you can't get a lever in.
  12. My understanding is that emulsion tubes are the tubes which the needle runs in, Jets are screwed in at the end of the tubes
  13. drewpy replied to martin43's topic in Yamaha Workshop
    sounds like timing to me, I put my thumb over spark hole to get feel for the compression then I know the timing marks will be tdc.
  14. drewpy replied to CKJDJK's topic in Naked
    yamaha only made xs240, xs360 xs400 xs500 xs650 (twins) xs750 xs850 (triples) and xs1100 (fours). no such thing as an xs600 need to go back and find out which it actually is. may be get the engine number, number of cylinders would also help.
  15. no problem
  16. drewpy replied to vishal's topic in Classics
    Get yourself a manual and read it. Haynes should do one for your bike and it tells you what needs doing at what intervals and how its done. That's how I learned.
  17. drewpy replied to yamman06's topic in General
    Smartarse
  18. drewpy replied to yamman06's topic in General
    shag was also a pipe tobacco
  19. are there resistors on your LEDs? maybe the relay has them also so that the extra resistance will lower voltage enough to cause the symtoms you describe. I am not an electronics expert so don't take my suggestion as gospel!! drewpy
  20. yamaha dealer will have them and speed & sport, bikebandit, motogrid
  21. drewpy replied to skullarms's topic in Classics
    not hard, you use ebay Item number: 140075701437 put item number under buy section>search german site but takes paypal and I've bought plenty from germany!
  22. you need the registration number. If you haven't got one then you will have to reregister anyway. you need to contact the vjmc and they will help in obtaining an age related plate.
  23. I've since been told autosol was too abrasive so didn't try. I have managed to get 1 nos downpipe and 1 being rechromed as we speak. The nos ones have twin walls to stop blueing. Still looking for a right hand silencer, tried classic bike forum as well. only could offer 3n6 silencer which i already have 1U4 anyone?
