Everything posted by drewpy
Im new to the forum - Hi eveyone
frank, no circumnavigating the "for sale" section please!!!
MOTORCYCLES THROUGH THE AGES BIKE SHOW
another manchester show @STALYBRIDGE ADMISSION £1 and then there's 3 sisters wigan, preston and district motorcycle racing!!
The Junction Function
hi goff, is there food there or do you have to bring everything yourself? drewps
ShoKz on the road
because you dont rev above 2k
Value of 1978 XS 500 E in excellent original condition
none if you live in afganistan!!
1980 XS 400 Wheel & tire?
sorry, when I meant wires I meant wire wheels!!
RD 400 master cylinder on a XS 500
I have an xs1100 16mm master cyl driving two calipers up front. the bore sizes offer a different feel to the brakes, and not always for the better. my lever is rock hard and that's the way I like it!!
Missfire @ idle ONLY when fully warmed up on RT CYL
I wonder if the pilot screws have snapped off in the carbs. if you can totally unscrew the pilot screws and they have a blunt end, then thev'e snapped off. If they are as sharp as a needle then your OK on that one. does sound like running weak on the right, some xs's had different size jets etc in each carb to compensate for this kind of thing!!
Posting in wanted section
is your browser up to date? if you've posted before, there must be something that's changed recently!!
Barking bike (?) concept
great vid, not sure about the voice over, should be a brummy accent methinks
82-85 xs 400 fuel tank cap
have you tried yamahatopdog?
Newb here with 81" xs400
http://www.raask.se/ind-eng.htm
Do I need a new stator?
fuses blow because there is a wiring problem or something is earthing out (eg rectifier) putting 20a fuses when its suposed to be 10 amp is looking for trouble and is not the way to repair electrics.
Whats the biggest rear tire I can put on a 78 xs 400?
I'm running 33 front and 36 rear on my sizes!! and you can have tubeless tyres, but as MD says you gotta get some tubes in there. the only xs 400's with tubeless are the dohc ones!
- My first post
xs500b electronic ignition kit
try here no mention of the 500, but i'd email them anyway bought an eletronic box from this guy gigavolt in germany, its still going strong
shouldn't be any wobble. there's a mismatch of tyres there as mdsims says. also check steering head bearings for notchiness and slackness. what are your tyre pressures?
what happens when you try?
Horizons Unlimited Mountain Madness July
sounds great, let us know how you get on drwps
are you running wires?
size, 90 is just one figure. i run 90 x 90 x 18 front and 110 x 90 x 18 rear both BT45
Thunderbirds are go!
Foamy's Always Babbling
- Yamaha SR500 opinion
yet more tuning...
I got that when I put my floats too low. Had to rev and slip the clutch to get going. this is a weak fuel symtom ( for 4 strokes anyhoo!)
what tyres are you running?
