drewpy
Everything posted by drewpy
  1. Dru don't forget its a UK based forum so posting at 1:30am won't elicit a speedy response!
  2. to the yOC
  3. yea, xs400/250 stuff is compatible with the 360
  4. could be that the clutch has stuck a bit and it needs freeing off. I'd get the battery sorted and engine going, then bump start in 2nd and pull in clutch and brake at the same time. this should free it.
  5. weld a nut on them , even the recessed one. the combination of heat and a new nut works every time. If you have a welder it takes longer to set it all up than to do it.
  6. drewpy replied to skik's topic in Classics
    try tightening them first, maybe just loose. Whether it will pass, depends on the MOT tester but if you've noticed it you tester will too.
  7. fucksocks! well that just sums it up
  8. mine was £170 classic comprehensive for 2 bikes with an extensively modded tracker. Breakdown included £25 excess. Same as last year in fact.
  9. must admit, its gone shitty since Alex got married, perhaps its sulking!
  10. drewpy replied to Tzr125Man's topic in The Bar
    Peter Kris someone oop there will pipe in!
  11. drewpy replied to drewpy's topic in The Bar
    that'll be an rd50 then, they all run one one cylinder!
  12. yep. The CG125 I had did it!
  13. just got a PM and to all you newbies out there don't post like this; Hey Im currently new to the yamaha world I have a 1977 xs 360d and wondering if you could give me a clue on whats going on with my bike that's it, you tell me? and only 1 bleeding post too!! rant over!
  14. so you can read my posts? well done you
  15. look carefully and you can see a grey arrow, which means turn the sprocket to match up the holes. And always clean as you go!! there is an old adage; If you work in shit, you produce shit...
  16. Saturday 28th & Sunday 29th April 2012
  17. this years Thundersprint is on 13th MAY. Drewps will be there in the Cavalcade along with this beast. V8 Guzzi only 6 in the world, built 1950's and did 178 mph!
  18. drewpy replied to Airhead's topic in Classics
    I like big and little nips
  19. Peter, It says member on top of your avatar and professional means you are paid up.
  20. I'd try and borrow a go on your other dreams to see if they stand up. I met a few peeps whose dreams became nightmares especially harleys!
  21. drewpy replied to Airhead's topic in Classics
    what's with the double post?
  22. drewpy replied to Airhead's topic in Classics
  23. a cracking ride through Cheshire on the A50, stop at little chef near the A500, then on A500 to A34 to Stafford. A few years ago I rode into a freezing fog cloud and saw my hands ice over like the movies. cool
