drewpy
Everything posted by drewpy
  1. I used to use cornflake packets for gasketv material. lighly oil the part, press it on the card and you have an impression. Cut around it and viola!! C'est Bon
  2. M and P sell 'em
  3. to get it started , you can always suck on a clear pipe from the nipple till you see fluid emerging. (said the biship to the actress )
  4. drewpy posted a topic in Video Section
    ">" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525">
  5. a long shot, but can your fab man make a top tripletree which has a 2 " drop either side? bit like this __/----\__ not sure how safe that would be, but you could get him to do it at cost as the bike was too low in the first place!! drewps
  6. what!! someone nicked the carb off your bike!!! bloody hell
  7. yea give up!!...........not you need to get your parts together via the online parts book try www.cmsnl.com and then get a manual and read it. if the noise is on tick over it usually means clutch, but without hearing it and from where can't tell ya too much. why not act daft and see a bike mechanic who will be able to diagnose it straight away?
  8. Chris Pearson (writebike) used to put a pipe from the caliper nipple into the brake resevoir using wire to secure and then press the lever with the nipple slack and before realsing it tighten up the nipple. eventually you get a fluid circuit and you can see it sometimes just going back and forwards within the tube if you dont do the nipple trick. One last thing is to leave the lever pressed via a cable tie overnight to purge any errant air. drewps
  9. I have a calender and it was already on there so I sort of got my way. BTW Its bloody full and she also doing her nut about that!!!
  10. drewpy replied to Goff's topic in General
    a maybe a strip charge!!! then I'd have to change me name to stiffi
  11. drewpy replied to choppernorgate's topic in The Bar
    glad your ok mate and feeling so much better!!
  12. drewpy replied to yamaharob's topic in The Bar
    to the forum Rob
  13. drewpy replied to mervin's topic in The Bar
    I came from a largish familly and if we didn;t gob in our food it would be eaten by my siblings!!
  14. drewpy replied to Perro46's topic in The Bar
    well its morning somewhere
  15. drewpy replied to handai's topic in The Bar
    Goff your sig is driving me crazy, everytime i see it I keep singing that blasted song
  16. drewpy replied to wild foamy's topic in General
    and try fitforx the forks are "hard chromed" not the same as decorative chroming although you could get away with it for a few years ( i have at the moment) hard chroming is an engineering chrome used because it can be groung down to specs. used in hydraulic rams etc
  17. now I really can't wait to go I'll chack that rout on me map, cheers No car, just me XS baby. CB750F1 and a friend of a friend sorry Goff, the missus is already having a fit with me going without "discussing it"
  18. urr
    drewpy replied to divster's topic in The Bar
    if you are naughty, the mods will smack yer bum. the smacks get harder the more you are naughty
  19. drewpy replied to Perro46's topic in The Bar
    my friend borro dai ( i think!!)
  20. coil will only get hot if theres a fault or it can't fire the plug. Could be a faulty ht lead!! problem is the're bonded in, but you can dremel the side and pull the ht lead out and epoxy a new one in try swapping coils to check drewps
  21. drewpy replied to Goff's topic in General
    whatever turns you on, porn does it for me
  22. drewpy replied to Rich_B's topic in The Bar
    seems its fixed now, yipeee
