drewpy
Everything posted by drewpy
  1. FFS, tommy! more jam than Hartley's
  2. drewpy replied to jimmy's topic in Yamabyss
    well done, now you can take a back seat and let the missus work those moschops are coming on nicely. next year we should start a mo-group and pool our resources
  3. super glue the zip with the thick stuff just before you go out. hopefully he will go straight for the bag and you have him. if he doesn't it will just dry and you can try again.
  4. should be fine mate
  5. please use a bike oil, there are friction modifiers in car oil with will cause your clutch to slip. if the recommendation is 10w 30 I'd be happy to put that in
  6. As I've said, i use dev111 atf fluid in the Gilera need to check the specs for your bike, could be a straight weight or multi
  7. drewpy replied to Ttaskmaster's topic in Yamabyss
    jeez, good job it was a heavy bike to take the impact. whiplash will kick in up to a week later certainly after the adrenalin wears off glad you're fairly OK though
  8. sorry I meant NOT use engine oil (forgot me glasses) clutch will slip with car oil in.
  9. drewpy replied to combat41's topic in Classics
    have a look at my blog (in the sig) I fitted some meaty tyres in there. for a bobber the choice of tyre is firestones
  10. aye, been doing since 13, son taken it up too my fave is my Takamine acoustic. Building a Dean caddy (very slowly) and have about 5 guitars in all.
  11. gear oil has different properties than engine oil. For one its specific for gears and the increased compression loading on gears. Also gear oil foams less. Foaming comprises of air rather than oil, which is not good for protection. yes I know 4 strokes have combined gear and engine oil but the engine is designed with baffles plates etc. I personally would use engine oil on a 2 stroke.
  12. grey sounds like alloy in the oil was there any bits/chunks in the waste? I use ATF in the Gilera and that's red.
  13. drewpy replied to lauragilmour's topic in The Bar
    you would need to shape the rear frame for a seat like that. You will have to relocated all the electrics, smaller battery and then make a hoop for the rear and get it welded on. can't do one thing without changing something else I'm afraid. that actual seat bit is the easiest
  14. You can't help being touched by the heroics of some folk,
  15. drewpy replied to wallywant xj6s's topic in Naked
    if they get hot, they will tarnish. if you get a double wall down pipe then it won't tarnish.(never seen them though) there is a product called blue away which gets rid of it
  16. its an engine out job for that too
  17. I use stainless a lot, a2a4 is my fave as you can just get what you need. you have to take each bolt off to measure and use copper slip to reduce the electrolytic reaction between stainless and steel. no more rusty bolts
  18. didn't notice
  19. bolts for what? the whole bike, cases?
  20. its to do with the bore size of the master cyl. smaller bore less fluid pushed but a softer brake and may pull to handle bars larger bore, more fluid but harder feel
  21. drewpy replied to jimmy's topic in General
    the girls have Fanuary any way!
  22. drewpy posted a topic in Video Section
    2 words..............Brilliant!
  23. drewpy replied to drewpy's topic in Projects
    it did, now to finish it
  24. Don't mess with the ladies of HR
  25. drewpy replied to drewpy's topic in Projects
    yay, it lives Movember tash in full growth
