I just cannot believe how easy she started. Litterally 3 kicks was all i needed.
Not big swinging angry stamps either just kicks. Did spend a good bit of time getting the timing spot on.
May be stating the obvious here to some but the flywheel keyway is at TDC transposing that to a mark you can see made it easy to set TDC then measure the advance needed.
All gen gaskets, gen piston kit. Replacement inlet manifold with a new airfilter. Again genuine. The bearings too are yam. Save for the output shaft bearing.
Suppose it should fire right up....
