Everything posted by Cynic
Testing for electrostatic discharge
Define decent size. I have seen capacitors the size of oil drums....
Dumb shit I've done since getting my bike
2 stroke warning light bulb....... If you know. You know.
Measuring fuel - how without gauge
Huh? I use a lot less in the winter. Like 50 ish in the summer and 80+ in the winter rubbish.
Cleaned brakes + dot 4 fluid change = Brakes not working xt125x 07
Are the caliper pistons in contact with anything. If there is a gap between the piston and pad, pad and disc or both then there will be no pressure. If the pads have taken the space up and thats it try pushing them back into the caliper. This should force fluid back up the line and get things going. Oh and the pipe. Vital. Like having a bike with no petrol.
Nah no guesswork steve. Just write your mileage on the receipt when you pay for the fuel. Simples..
I remember my first electrical principles lesson at tec. Long before the nanny police. The lecturer came in and tossed a couple of capacitors into the room. They were charged capacitors i might add. The ones that caught them didn't habg on to em for long...
Fill her up check the mileage and zero the trip if there is one. Ride till it runs out and you switch to reserve. Check milage. Then fill up 10miles before that. Worked for me for the last 25 years.
southern meet.
Whats oxford for you 180, 200 miles. Thats why i said oxford or further. Kev might do it by car. Most of the squires lot are along the 62 corridor. Only be 150 for them to oxfordish land. The biggest issue is how many will actually turn up. Every year if the folks who say they will come to squires did would be brilliant. I dont really care being in northants anywhere in England is not really more than 3 or4 hours away. Cornwall would add a bit to that.
southern meet.
Ha. Well the original meet of the yoc is actually pretty central as far as mileage goes coming from either direction. Blackat has around 300miles to do to get that far south....he's a rough tough scott so he can cope. I'm thinking something futher south. More an excuse for another meet up more than anything else.
Midlands meet
Its not scary mate. All that campus totty is a joy in the summer.
southern meet.
Thats why i started by mentioning oxford. End of the day if there are people here who can get to the bmf or that ilk fair enough. Only prob with peterborough is the roads fall under linconshire constabulary. Not good, ticket first ask questions afterwards.
Northern Meet
Tdr 250. With the ride out and getting lost (tradition ask blackhat) more like 500 for the weekend. 2 wheels did it the first year on his dt. From ireland it was more like 800 miles.
Northern Meet
Speaking as one of the soft sotherners that made the 400mile round trip for the last 3 years. You have squires..... Hence the need for something further south....
after rebuild bike needs more air?
Easy do the math. 4000rpm = 4000 x 125cc gives 500000 cc of air. Thats 500 litres of air a minute. 10000rpm = 10000 x 125cc gives 1.25 million cc of air or 1250 litres of air a minute. You can get clever with velocities for given diameters and such but it does make you think. Becomes obvious why the power difference between 2 and 4 strokes too. You can halve those figures for a 125 single. As to the different top end. Think on this. If the bore is worn on a 4 stroke she burns oil and loses compression. On a 2 stroke there will be less draw into the cases as charge from above the piston will be drawn down reducing the pull through the carb. Just imagine losing even 5 per cent of the volumes from earlier and the effect on mixture and performance.
Removing rust from a DT tank, possibly the XJ tank tomorrow.
Not sure on this. Electolysis is a proven idea but it wont remove rust. You are extracting iron from the Steel. I dont see a benefit. You need to stabilise the chemistry in the tank. Ie reconstitute the rust back to iron chemically. That will stabilise the metal. Then seal the metal off from the primary villan. Ethanol and water.
southern meet.
Ok so bmf is a maybe.... Any more.
No john you have to paint/seal the metal afterwards.
Nothing. Once upon a time petrol had little or no moisture in it. And kept the tank clear. Your dad ever told you to keep the tank full to stop it rusting. Original be buggered. If you dont seal the tank it will rot out in the end.
Here is the link for the stuf i used...... http://www.tankcareproducts.co.uk/
Your stripping away the layer of metal the rust is attaced to leaving nice clean unprotected steel for the water to corrode. I'm surprised you could get phosphoric acid in any quantity unless it was very dilute. That makes battery acid seem like handwash. I cant remember the stuff but you need a chemical that strips oxygen then the iron oxide aka rust will return to the more stable iron and then seal it. Or use one of the complete sealing kits. I used one on the tdr. Only 60 or so quid. Just make sure they are ethanol stable and it will be fine.
So filling the tank with a couple of litres of acid is a good thing steve? The fizzing is the acid digesting the steel. Vinegar is primarily water with between 5 and 10 percent/vol acetic acid. Your making rust.
DT cutting out
Dtdan that is not a good idea. Put it in gear and rock the bike with the clutch in. Keeping the revs up and clunking it into gear can damage the dogs or the selectors.
DT 125r cylinder/head swap over
Think some of the extra cc comes from stroking the crank. You already have the best option. Give it a try and see. Once the top ends are on the bench its just a case of measuring up.
southern meet.
A southern meet has been mentioned several times over the year. Right oh. Lets have some options and see if we can make it real. Dont want the coast. Nor that crap hole of a capitol either. Merv how far could you take one of your fleet, you are one of our most southern members. Realisticly there will only be bout a dozen of us so there are plenty of campsites to use all over the country. Maybe someone knows something squires ish around oxford maybe. Lets have some idea's
Happy New Year!
Think i can prob drive legal now. .... Happy new year. Everybody.
