Neta exhaust system obstructs oil plug
Camus
This post is 5871 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi everyone , just joined.
I have a '89 xj600 and want to change it's oil/filter , however the 4 into 1 neta exhaust seems to partially block access to the drain plug.... does one normally have to remove the system or can it be drained without doing this?
Thanks in advance :unsure:
I changed mine without removing neta exhaust, was a bit fiddly. Cant remember exactly but i think i used a long socket extension, not easy but doable.
typical fu**wit designers, they dont ever have to use the things
merv
You can't get a socket on the drain plug but it's fairly easy with a ring spanner. You do need a ring spanner with a good off set, a combination spanner is no use. I find that you need to feed the spanner in from the front of the bike and with a bit of dexterity you'll get the job done.
merv
Thanks - It's as I suspected then , a pain in the a*s , will be giving it a go with neta in place.
Thanks for the advice, I was experimenting with a ring spanner and it looked really awkward. Learn something new every day eh?
