Yamaha YBR 125 engine swap
UglierBoss
This post is 998 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all, quick question if I may:
My YBR has a noisy knocking engine and so I have a spare to swap with it missing only the alternator coil but it has the flywheel/magneto rotor. so I put the swap engine in and used my original coil and cover from the first engine. Im getting ok compression 80ish so i think the valves need cleaning up but I am also getting error 46 about power supply to Fuel injection. Can i assume the flywheel/magneto rotor on the swap engine is bad? I cant see what else has changed...
