June 10, 201412 yr I need to replace the fork seals on my bike as one has a small leak what tools do i need is there anywhere i can get step by step instruction preferable with a video or pictures.
June 10, 201412 yr Yes mate go to and watch this, should tell you all you need to know. Hope that helps?
June 10, 201412 yr Moderator The problem sometimes is that the inner cylinder can spin in the lower leg. This means that the fork won't come apart. Other than that it is a straightforward job. I recently had 2 done but didn't have the time to do them myself so I got a local bloke to do them for me - same day - for £20 and I supplied the new seals.
June 10, 201412 yr Try this wee trick first, I think it was posted on here a year or so past, and the guy made his own out of a coke bottle sealmate
June 10, 201412 yr That was ME Jimmy and it worked to I forgot all about that, getting old I suppose !!!
