yamaha xv125 replacing fork seals
I need to replace the fork seals on my bike as one has a small leak what tools do i need is there anywhere i can get step by step instruction preferable with a video or pictures.
Yes mate go to
and watch this, should tell you all you need to know. Hope that helps? :jossun:
The problem sometimes is that the inner cylinder can spin in the lower leg. This means that the fork won't come apart. Other than that it is a straightforward job.
I recently had 2 done but didn't have the time to do them myself so I got a local bloke to do them for me - same day - for £20 and I supplied the new seals.
Try this wee trick first, I think it was posted on here a year or so past, and the guy made his own out of a coke bottle
sealmate
That was ME Jimmy and it worked to I forgot all about that, getting old I suppose !!!$T2eC16F,%21%29sE9swm%28sciBRCilD4dv%21~
I wasn't sure if it was you or noise and didn't want to credit the wrong fella
Thank you all for you help it will be very useful :)
