Hi ,
made a search but cannot find the recommended tyre pressures . I also require the torque settings for the two nuts on the rear axle . If anybody can assist , I would be most grateful.
Rear spindle nut - 80 ib -ft, tyre - 25/30 lb ... :icon_wink:
I have 45's on my TDR and they feel much better with the slightly higher pressures.
definetly go higher pressures on modern rubber , the original 23/29 psi in modern tyres will make it handle like a shoping market trolley
