Chain break, now engine won't start
Too right - can't afford to keep offering to buy drinks for everyone; I'm part Scottish!! :)
  • Replies 122
  • Views 17k
  • neversaydie
    neversaydie
    Anybody got any ideas how to clean oil, petrol, grime and carb cleaner from the kitchen sink before SWMBO gets home? lol Tell he you had to mend the boiler
  • My battery still in-situ, only using car as jump. Plug is wet. Battery water levels are ok. Just taking a break while I clean up some blood - don't ask!! is it the dick then?
  • AndrewElvisFan
    AndrewElvisFan
    I was just going to soak it in cheaper motor oil, fit it and then spray with the thicker chain oil..... Every hour!! I've gone for the more expensive DID chain so I'll not be neglecting it again. Appa
I am glad you have it running and it doesn't seem to be something expensive. It does seem like you have done some "preventative" maintenance as you have got this sorted.
Even if the battery optimiser said that all is good, I would seriously think of changing the battery in the near future.
Not sure when the air filter was changed so add that to your list.
I have an Optimate 4 charger/optimiser and it is very good. You can get a set of "tails" that permanently connect to the battery and you can just plug the optimiser into that making battery maintenance very easy. You can also plug in a aux socket which allows charging of phones, satnavs etc while riding the bike.
Charger, front brake pads, front tyre, air filter, then battery! All on my list for the next couple of months. Thanks again!
