December 3, 201311 yr I'm going to be moving in the new year and I need to think about storage for my bike(s). I want to get at least two more bikes on top of my WR. I want a 125 2T and a crosser for the weekends. I've been looking at the metal sheds you can buy and they seem to be the best option. I would imagine that they are really thin and easy to break into. Does anyone have one, or something similar?
December 3, 201311 yr Few of my mates have them, and they seam to be pretty good, if your storing your bikes in there id suggest some motion sensors. Word of warning tho, wear gloves when you build it as your cut your self less if they where made of razor blades
December 3, 201311 yr Yup condensation, like an oven in the summer, and T leafs with tin openers.... A decent wooden shed on a concrete base with ground anchors probably a better bet.
December 3, 201311 yr Moderator You can get some wooden sheds that fit through a standard doorway if you don't have a side entrance. Not all wooden sheds do.
December 3, 201311 yr You can line a wooden shed or even a tin one come to that with rockwool battens to keep the damp out Grouch, they even do a spray on stuff for the roof panels.
December 3, 201311 yr Author That would be ideal, I could run an electric extension in there and use it as a hideaway haha
December 3, 201311 yr depends on how much you want to spent,id suggest a bespoke built shed,ive bought a standard shed but 'uprated' the security on mine...bespoke door fitted with 2 5 lever deadlocks and 2 chunky padlocks. so 4 defence mechanisms to get through....oh plus my staffy to get past as well
December 3, 201311 yr Just a thought Grouch why not try and find a new place with a garrage,if your moving anyway then move to a place with the required essentials........fully wired man cave,stove, bed,washing machine,shower,place for guard dog..who need's any more than that?
December 3, 201311 yr Author depends on how much you want to spent,id suggest a bespoke built shed,ive bought a standard shed but 'uprated' the security on mine...bespoke door fitted with 2 5 lever deadlocks and 2 chunky padlocks. so 4 defence mechanisms to get through....oh plus my staffy to get past as well Was thinking 3-4 hundred, that should get a decent shed? Just a thought Grouch why not try and find a new place with a garrage,if your moving anyway then move to a place with the required essentials........fully wired man cave,stove, bed,washing machine,shower,place for guard dog..who need's any more than that? Ideally I want a garage, that would be a result. And to be honest the kind of houses/neighbourhoodsmy girlfriend is looking at ill end up in a 5 bedroom detached with a double garage haha.
December 4, 201311 yr tbh you'll be stretching it abit even at 400 for a shed big enough for 3 bikes,bearing in mind you'll want to spend a few quid on decent security. if you want quality and the size you want you'll be looking more at the 800-1000 pound mark. its always worth checking ebay for 2nd hand sheds(there are some good quality ones out there),if your lucky you'll find a decent local one at the fraction of the cost of a brand new one
December 4, 201311 yr Author Cheers. I think I want new so it comes with a warranty and they can erect it professionally for me.
December 4, 201311 yr Moderator .............. and they can erect it professionally for me................ That sounds so wrong!! Have a look here for examples - both wooden and metal - LINKY
December 5, 201311 yr tbh you'll be stretching it abit even at 400 for a shed big enough for 3 bikes,bearing in mind you'll want to spend a few quid on decent security. if you want quality and the size you want you'll be looking more at the 800-1000 pound mark. its always worth checking ebay for 2nd hand sheds(there are some good quality ones out there),if your lucky you'll find a decent local one at the fraction of the cost of a brand new one I bought a 10' x 10' shed last year cost about c£800, but then I had the hardcore, concrete base, wiring, insulation and finally lined the inside with sterling board. All in all it cost about £1300. I've got 3 bikes in it at the minute (well 2 and a half built project), coupled with shelves and cabinet, there's no room left for doing any maintenance, work etc... Oh wait, it's Grouch that wants the shed.....Strike my last sentence from the record...sorry mate
December 6, 201311 yr If it were anyone else, I'd suggest buying a shed load load of old floorboards and frame timber and building your own You dont get much for your money with bought sheds these days, paper thin boarding, cheap tacky composite floor, rotten through in ten years Always remember, buy/build the biggest shed you can cos it'll always be full and never big enough
December 6, 201311 yr A shed-thread!! Something I cant resist! As far as tin sheds go, be careful if its in an exposed position. A friend of mine got one installed and two weeks later there was a storm and he found it in bits in a nearby field. Luckily it happened before he'd got round to storing his beloved Ducati in it! I would avoid buying cheepo sheds from the usual DIY and gardening outlets. They're cheep because they've used the thinest and cheapest wood they can get away with. As already said, if your looking for a decently constructed shed big enough to house 3 bikes then your looking around £1000 or so. If you've got access to reclaimed wood in sufficient quantity then the DIY route is the way to go. You can then make it to your own requirements and far cheaper too. I recently made one to serve as bike storage and workshop. Its an oddball size cos I wanted to maximise the space I had available. Ordered all the wood direct from the timber yard and set too with a saw and nail gun! Total outlay was about half of what I'd have spent on a similarly constructed pre-fabricated bought-in job. But still cost me well over a grand, especially when all the electrics etc are included. And just to prove that whatever you build, it wont be big enough!!............. V.
