looking good :) you could do my DT50 plastics whilst youre at it, peacock blue please!
that reminds me, i still have some SR bits kicking around here,
  • Replies 121
  • Views 18.1k
  • lauragilmour
    lauragilmour
    Had a good run out this after noon and best fun I've had in a while, the wind whipped me out at one point but other than that it's brilliant, doctors should honestly prescribe bikes for depression it'
  • Want to buff my nuts?
  • She probably doesn't want to take a piccy of her "little beauty" for you bunch of pervs...! Ha ha!
Sooo I'm having a little issue, before all this it's started fine now it just doesn't want to start! I put the key in, neutral light comes on, pull the choke, there's petrol in and I press the starter button, and it just makes the noise of wanting to start but it doesn't actually start, I've had a look at the battery, it's topped up with deionised water, the connections are solid, the wires don't look bad any ideas on what it could be? :(
so you can hear the starter motor turning ?
have you checked for a spark at the plug ?
also check the fuel lines are connected right make sure any breather pipes are clear also it may be your carb needs cleaning out.
I haven't checked yet but sometimes if you try to start you hear a drill like sound? Any ideas
Had a look at the spark plug and no sparks
paint looks great, did you lacquer though?
check connections on the TCI and the obvious fuses, just take each one out and check connections.
also did you hook up the live feed to the fuse box when you reconnected the battery?
It was a matt lacquer :)
And I've got the battery on charge at the moment and once it's charged I'll see and if it's still not firing up I'll go through and check all connections
Sounds like starter not engaging" :eusa_think: , And" on the fuel tap , is there a prime position ?
Drill sound is the starter not engauging the bendex,you wont have spark unless the motor is actualy turning over.
DID you rember to hook up the ground/earth from battery to motor after ploishing in there.After you got the battery charged and checked all conections then get back we'll get you running again,but its someting simple if you look hard enough I'm sure you will find it.
Kill switch on,netural wire(blue) hooked up, side stand switch hooked up coil pluged in
Have to agree with Noise the rusty carb clamps and bolts pull down all you nice work,can't waite to see the piant in the sun not my colour choice but I like it ,might grow on me when I can see it change colours if you can get it on film er aaa digital haaha.
Spent a bit time going round taking covers off and checking wires! All in all she starts and doesn't cut out now! Thank you guys
Ok so stop teasing us with naked picts,how about one with her clothed
I took a picture but the lighting is just awful will try and take some better photos when the sun comes out ;)Posted Image
In Newcastle.... :icon_eek:
I take that back" fore :jossun: cast 11-13 degrees this week sunny too ,,
  • 1 month later...
What happend to Laura was so looking foward to the picts of her little beauty outside?
Too busy riding probably! :D
Last active JAN 28th ,, shes lurking,,, :listen:
Ha ha!
Foamy" Kev, you"ve been called,,, :popcorn:
Best drink.out there foams, other good one is a well matured glenfidic
My 2 favourite spirits mate
