August 26, 201312 yr Author Moderator Just pulled it apart. 2 broken rings! It's been making a right racket ever since I put my spare barrel on. I'm surprised it lasted this long...it was worn out and ported, last oversize chinese piston no doubt All is not lost though. Jason kindly sent me another barrel up and it's at the re-borers from last friday...then it'll have to go for aqua blasting because it's cosmetically grotty. Hopefully I'll be back on the road soon and it looks like I might be running in if I get it sorted for the rally
August 26, 201312 yr Moderator Just pulled it apart. 2 broken rings! It's been making a right racket ever since I put my spare barrel on. I'm surprised it lasted this long...it was worn out and ported, last oversize chinese piston no doubt All is not lost though. Jason kindly sent me another barrel up and it's at the re-borers from last friday...then it'll have to go for aqua blasting because it's cosmetically grotty. Hopefully I'll be back on the road soon and it looks like I might be running in if I get it sorted for the rally So running it in to Squires? Will it make "the hill" on the Saturday??
August 26, 201311 yr Moderator So running it in to Squires? Will it make "the hill" on the Saturday??
August 26, 201311 yr Author Moderator So running it in to Squires? Will it make "the hill" on the Saturday?? Ha...thats a good point! At least i have the temperature indicator, that'll help
August 26, 201311 yr Well that sucks so close to your guys big event,did it take the bottom end with it? Last bore is always sketchy now all that fancy tuning is out the window and your going to have to start over, at least you have all the stuff to do it now. Good luck hope you get it back together and running fine for squires
August 26, 201311 yr Author Moderator It was only idling at the time, I was just waiting to pull out of a junction luckily, thanks for the good wishes dt
August 28, 201311 yr Author Moderator The barrels at the borers, pick up friday saturday it's off to the aqua blasters and then to work for a respray I'm waiting for a set of rings to end on ebay, got a new piston and pin and small end if it all goes exceptionally well she'll be back together next week when the rings arrive ...hopefully
August 29, 201311 yr Moderator that's the hard part, waiting for parts. especially when you want to get in it!
September 1, 201311 yr Author Moderator It's done IT175 head, heas a better combustion area Cant wait to get out!
September 1, 201311 yr Moderator Once again Paul, spot on. You have a couple of weeks to get those rings bedded in before "the big one"! Looks great!
September 1, 201311 yr Aah so you have opted for the it head with central spark plug! I may try this too, let us know how you get on!
