Appreciate the link, but nah, want to learn to do my own fibreglassing, that way there will only ever be one of that kind in the UK and it will be mine, the whole point of this bike is to tailor it to me :)
  • Replies 117
  • Views 17.7k
  • Sure it's not a single and you were seeing double when you brought it Steve?
  • wild foamy
    wild foamy
    By some strange miracle I was SOBER when I bought this one
  • so is this going to be your first electric bike (if you need all that room for the battery) lol
good luck with the fibreglassing Mate messy stuff some good tips on youtube though
Bit more work today, i stripped the battery box and electrics out of it, i can fit the reg/rec and starter solenoid under the seat without having to extend any wires, Fusebox will be mounted on top of the inner fender, Battery just behind it and will probably move the indicator relay and various other little boxes up under the headlight, here's how it is right now
Fibreglass is at home and hopefully by the weekend i will have a top yoke and maybe some bars ready to go on it aswell as some universal headlight mounts, once the yoke is on i can mount the clocks and maybe see about getting it started, will run the stock tank until after squires, may fibreglass a new airbox aswell although because the box will be taking air from the front of the bike im concerned about the vacuum from the front carb causing the rear carb to run lean
could you not make the airbox twin channel ?
its the complete yoke tree you want isn't it ?
Just the top yoke bud, from what ive read online it should be a straight swap, did you send the full set?
Cant really make the airbox twin channel as space is unbelievably tight under there, have maybe 25-30mmmm of clearance above the rear carb and about 40mm on the front carb if i run without the rubber manifolds that go from the carb to the airbox, may just make a lower airbox with louvres in the top and panel filter running the full length/widht of the airbox
I've packed the lot mate, you never know you might need them,
I have all the parts i need now apart from some new tyres! :D.
Headlight mount, top yoke (cheers tommy!), battery, lenses, ace bars and fibreglass kit are here, can get those yokes/bars on sunday night and start fibreglassing my tail piece, then mount the headlight and clocks on monday, move all the electrical stuff and hopefully get it running by the end of the week :)
Glad you got it OK foams hope it fits! Hope to see the XZ at Squires good luck with it mate.
this should be good.....
Do I detect a hint of sarcasm there Drewp's :eusa_whistle:
Oh really, sarcasm?... that's exactly what i need...
I thought you said it was tyres ?
No ive got a brand new set of them, avon AM26 front and rear, won them for £120 which is slightly more than i would have wanted to pay but considering M&P want about £150 for a set its still better than buying brand new
Oh foamy ive got a pair of very lightly used Avons you could have had!
foamy this probably a stupid idea!! but here goes anyway, could you bang f#ck out of the tank with a hammer just to take the sharp edgers off then fibreglass over it or even body filler? could be a lot easier than starting from scratch making a new tank.
also it would be funny as f#ck if it goes wrong
nah, will run with the tank it has until squires, then look in to getting a new one made, got some details of some guys in devon that Drewps used for his tracker so will drop it down there some time in september and see what they can do for me.
shame it doesnt have a kickstart, then i could just run a smaller battery and not have to worry about where to put it.
