when I took out the bearings of the rear hub, i noticed that one of the bearings had a bit of Italian tin wrapped around it. This i believe is because the hub was too big for the bearing from the factory!!
I can tell it hasn't spun as i can still see the cast markings and no signs of wear :crazy:
apart from reusing that bit of tin,along with bearing lock, has anyone else got any suggestions?
things I have thought of;
1) Just bearing lock = too much gap
2) peen the alloy inside = won't get it central, can fail
Is there a bearing that would fit? With a tiny bit of machining.
cut a strip from an aluminium beer can :thumb::D
that's basically what the Italians did, I'll keep it as its got Italian writing on it too.
Keep it "original" :eusa_whistle:
Next size bearing up with the same ID, hub machined out to suit the OD, might have to have depth increased atad to suit too
not much meat in the hub as it shaped like a "tunnel"
Can you have a disc turned that just clamps onto the outer race, and is secured onto the hub with screws/bolts, with the tin can shim centralising the bearing?
I would have a look into getting the hub machined out and an interference fit machined liner made with an I/D that matches the O/D of the brg (perhaps from steel) then warm the hub and freeze fit the new liner, That is unless the cost is too prohibitive,
If your wheel bearing surface is knackered then why not try a replacement wheel, I mean how much would that cost as opposed to all this milling and clamps that have been suggested and as OG says what's wrong with the "original" Italian tin can if it ain't broke (well not much) don't fix it. :crazy:
its a 5 bhp ped not a bonneville speed week contender...jeez whats wrong with the tin can !
:hah: Class.
Drewp's i had this very prob with "Mini Bike" rear wheel.
I think it happened cause the rear axle wasnt tightened propperly,,,,,, the bearing was spinning in the hub and made it bigger,,,,,new propper size bearing i bought was loose.
Anyway,,,, all the bearings have numbers stamped on them,,,,,all the numbers mean different things (as usual)
So you can buy bearings that have the same internal diameter as yours but have a heavier outer diameter. One of the numbers stamped on bearing mean heavy or lighter outer diameter.
Only thing is,,,, there isnt much of a difference between the two types,,,,,, so ya might have ta use your Italian tin yet !!!
Thanks Pat, I know about the international number standard its how I buy my bearings now, its much cheaper. I even buy oil seals that way too.
6201 is the the bearing number 12mm bore, 8mm depth and 32mm OD the next size up is 37mm OD
depending what the gap is you could spin up a bush to sit between the hub and the bearing, or just use your italian tin with a bit of loctite, if it aint broke dont fix it right?
you can get a hub on a decent size lathe. set it up off a disc brake mount or unfailed bearing housing,not the o/d of the rim.machine it to the next bearing size up, there are plenty of charts on the net regarding bearing sizes.
do it properly then you won't be wondering if it's about to let go.
If ya go away from the international number standard, ya can get different sizes,,,,,,,
they prob arent as good a quality but there still a bearing. (just change it more often)
12mm ID, 34mm OD, 11mm depth.
mabey 11mm is too thick for ya
