January 9, 201313 yr I've just bought some Redex after being advised to, my tank only has a ten litre capacity and it says you have to put half a bottle to fifty litres! Will it matter if I put a little bit too much in because I can't get an exact measurement to put in.
January 9, 201313 yr No it won't matter but may I ask why you want to put it in is it running rough? If your just putin it in to keep the carb clean put 1/10th of the bottle in but even then not realy nessary as most new fuels have cleaners added .It's only when the fuel is alowed to evaporate the gum and varnish starts to build up,
January 9, 201313 yr It will smoke a little but I dont think it will do any damage. Back in the day I used to pour some directly down the plughole on my Triumph Bonneville and run it a bit before I lifted the head off (the seals for the pushrod tubes would fail about once a year). The piston crowns would be well clean so I assume the redex done its job
January 9, 201313 yr Moderator Smoooooking. Be careful with it as it will take all the deposits off the cylinder. Some would say dont use it, I would too but I love the smell and white smoke.
January 10, 201313 yr grouch you dont need to be exact with the measurements i pour it straight into the carbs now and again with the engine running on tick over gives of a whole lot of crap from the exhausts but thats it doing its job just add a little four or 5 caps full when you fill up for a couple of fill ups that way any crap in the system clears without any residual damage
