Moderator Airhead Posted November 18, 2012 Moderator Posted November 18, 2012 well done on posting the pictures, the comments arent all readable though you should comment in the post above or below the pics so it can be read are they fuses on the starter relay?
cbray91 Posted November 18, 2012 Author Posted November 18, 2012 thanx. i did edit them on photobucket but for some reason they posted un edited version.yea they are
cbray91 Posted November 18, 2012 Author Posted November 18, 2012 this says earth wire attatched to crank case
cbray91 Posted November 18, 2012 Author Posted November 18, 2012 that ones clearer writing wise but it still uploaded sideways sorry guys
Moderator Airhead Posted November 18, 2012 Moderator Posted November 18, 2012 whats the white looking wire on the relay? the diagram has it as a brown one
cbray91 Posted November 18, 2012 Author Posted November 18, 2012 that wire is sort of a light brown its just glare from the flash. i think it goes into the cdi
Moderator Airhead Posted November 18, 2012 Moderator Posted November 18, 2012 well have you got a multimeter, there should be 12v at the Br wire when the ignition key is in ON posn
cbray91 Posted November 18, 2012 Author Posted November 18, 2012 i used a test light earlier and double checked it there now theres definately power to all 3 small wires. i pressed the start button and theres still no power at the startermotor terminal. regards c.bray
