Fz600 Gulf
thats some work your putting into that yoke.. great handling bikes tho so well worth it..
  • Replies 333
  • Views 61.7k
  • also went out with Tommy to suss out the timings for the ferry at Liverpool
  • found me spark; combination of things 1) couldn't get to fire manually off battery, so took off the caps and the spark was very weak. even though Dyna say it doesn't matter which way the connecti
  • Just done my cam cover in VHT crinkle finish   looks the dogs B
managed to weld on the new top mount for the r6 shock, about 25mm longer, which is fine
old mount
new mount
off to Andys bikes in Derby to drop off the plastics
shockingly weld-un :biglaugha:
well drove 200 miles today to give the painter my plastics, only gone and forgot the fuel tank :madflame:
left it in the shed as it stunk, so I borrowed a box off him and said he can have it back when I send the tank :D
asked it to be ready for end May
What a plonker drewps :hah:
He has addled his brain with all that 'old man porn' he has been trawling through lately :eusa_whistle::eusa_whistle:
did a bit more today, noticed that the lower crank looked bodged so took it to kickstarter motorcycles in manchester for them to have a look. turns out its body filler :eusa_shifty:
took it back home and prayed that it was only the post that had gone and not the crank itself.
after a tense 10 mins using a wire brush drill attachment, i finally breathed and it was just the post that had been bodged so i tooki it back to KSM and he welded it up in a few hours.
so I went to manchester city centre 3 times today, luckily its only 10mins if the traffic's clear
red in the photo for some reason on this one
Aye, I think the red is that stretcher/filler fibre glass stuff. Used it few times in the past filling in holes in car floors
there's no red there its only in the picture!
it could be the laser the phone uses to auto focus and exposure
Red eye :spin2:
got some wrecked dogbones off ebay for £4 so I can check if they fit
yipee, they do fit so all i need to do now is work out the ride height when the bike is together and either use standard YVPS dogbones or get some shorter ones
Will this change ride height ? is the R6 unit firmer ,?
the ride height will be adjusted via the dogbones when the bike is together
the r6 is about right and has the added benefit of rebound adjustment
  • 1 month later...
got some tasty 4 pot front calipers of an FRZ400rr. these are fitted to TZR250 bikes too
and some Raask rearsets. brake side is good, gear change side is a lash up with only the back plate any good. Hopefully I might have some kind folks give me the missing bits
did a bit today, well a lot actually. forks in swing arm in, wheels on brakes in and the postie brought the pads striaght to me as I was hanging the brakes talk about timing.
the rear wezmoto brake pipe is too short, so that will have to go back :(
put the raask rearsets on and they are too high for me, so I'm going to stick with the original set up so I can be less of a contortionist!
the front brakes and M/C look good though, just need to bleed them
lookin good Drew :jossun:
Shure is" the swingarm,, its of a moto-xer ? :eusa_shifty:
cheers
Yamaha used their "new" monocross swingarm in the FZ as OEM Blackie
I don;t expect you to post pics but is the paint job finished
no, not till end May/beginning June
the bike can be ready for then as there's nothing worse than trying to store fairings off the bike
