4 O rings = £23
:help: please,
I want to check the valve clearance on my 2007 ybr 125.
Manual says to replace the O rings, 2x valve clearance caps, 1x crankshaft end cap and 1x timing inspection cap.
Only place I can find is AJ Sutton, the 4 rings cost about 7 quid but when they add p+p (to N.I.), = 23 quid :o
:shrug:
Anyone know where I can get 'em and without the astronomical p+p???
93210-44889-00 cylinder
93210-14899-00 timing inspection cap
93210-328A4-00 crankshaft end cap
have you tried your local yam dealer
or if you have the sizes www.simplybearings.co.uk
No Mervin, I don't know the sizes.
I'll call the Yam dealer tomorrow.
Thanks for the link, I'll be bearing it in mind, lol.
Just a side note you don't have to replace them if they don't rip.I have reused them without leaks on many bikes over and over again.
I agree with DT50 above.
Type your numbers into the top parts box here to see ther models that may help
Nice one dt502001!
Greased rings and re-used...... Job done.
Thanks everyone.
Always glad to help
