Posted August 27, 201114 yr i just bought a TZR 125 on a 89 reg and it is getting completely stripped down and re-done , i will be getting all the frame re coated and all the metal parts of the bike powder coated including the wheels, also will be having a full re-spray back to its original colours but the only problem i got at the minute is that i need to get hold of a full original sticker set so any help regarding that would be most appreciated thank you
August 27, 201114 yr Here ya go, not the cheaest place to buy from, but the part numbers are there for you to use at other shops maybe? hope this helps http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?PageiD=24&modelID=9124&uID=0
August 27, 201114 yr Author thank you guys for the link i will try them, any actual links to a set would be very appreciated
August 29, 201114 yr Author well thats the plastics all stripped off and De-stickered now all needs to be done is rubbing down and paint the fairings and then get the frame re-painted. coming along nicely i think
August 31, 201114 yr Author finally got the fairings filled and rubbed down and also got the frame flatted down ready for paint so should be getting that done tomorrow, think a full engine rebuild is on the cards for tonight. hopefully should have the bike done for the weekend if all goes to plan :hyper:
