July 6, 201114 yr i have acquired a intruder 125 and have found some problems... the solenoid is gone which i have ordered there is a loose connection in a wire from the ignition barrel also the bike will start when i bypass the solenoid but only with the choke on it wont run even when warmed up (tick over or accelerated) i see this problem as the carbs but i dont know how to regulate the mixture anyone have any advice? thanks in advance
July 7, 201114 yr Moderator Dan I assume you are asking for advice about the 'only runs with choke'...this is often a blocked pilot jet, strip and clean the carb thoroughly paying particular attention to this jet.
July 7, 201114 yr Author its not mine lol someones paying me for working on it ive bought some carb cleaner and will take your advice thanks oldgitonabike
July 7, 201114 yr Moderator Well funny you should say that we had a thread on the aircooled forum the other day, what is the worst bike you ever owned and most of em where Suzukis,
July 17, 201114 yr Author ok carbs done but no cigar... air filters are off loud knocking in front cylinder as soon as i accelerate it misfires then cuts out but will accelerate upto about 3000 rpm when the choke is slightly on any ideas? im at the end of my knowledge
