rob.patton Posted May 25, 2011 Share Posted May 25, 2011 hi i got a dt 125 r as a project all going well top end rebuilt runs well apart from now its started leaking fuel out the over flows on the carb i striped it down and it seems all ok can any1 help please Link to comment Share on other sites More sharing options...
NEV Posted May 25, 2011 Share Posted May 25, 2011 hi i got a dt 125 r as a project all going well top end rebuilt runs well apart from now its started leaking fuel out the over flows on the carb i striped it down and it seems all ok can any1 help please Sounds like your float needle, or float isn't sitting properly, carefully take off carb, undo the 3 screws at the bottom of your carb so you get into the float chamber, check needle or the bar/pin that holds the float in place then, carefully put back on carb, as tilting it can make the bar/pin come out. Link to comment Share on other sites More sharing options...
