BenFromSpain Posted May 25, 2011 Share Posted May 25, 2011 I rescued a virago 1992 xv750 and trying to get it up and running again. So far the electrics are back up to scratch and both cylinders are firing (only just). The main problem is the carbs, the rear carb has the pilot screw mashed/mangled into the carb body and the choke has seized and snapped off. So this being the case I am looking at other options. 1) buy another set of carbs (very expensive) 2) convert to single carb setup 3) use other carbs I would like to know other carbs can be used for both the single setup or different set. Thanks in advance. Link to comment Share on other sites More sharing options...
NEV Posted May 25, 2011 Share Posted May 25, 2011 I rescued a virago 1992 xv750 and trying to get it up and running again. So far the electrics are back up to scratch and both cylinders are firing (only just). The main problem is the carbs, the rear carb has the pilot screw mashed/mangled into the carb body and the choke has seized and snapped off. So this being the case I am looking at other options. 1) buy another set of carbs (very expensive) 2) convert to single carb setup 3) use other carbs I would like to know other carbs can be used for both the single setup or different set. Thanks in advance. Hi Ben and welcome m8, don't know a deal concerning Viragos m8, but If you are near to Valencia I can put you on to a bloke who does. Link to comment Share on other sites More sharing options...
BenFromSpain Posted May 25, 2011 Author Share Posted May 25, 2011 Hi Nev, Thanks for the reply, at this point I will take anything that might provide options. If you could send over the detials that would be great. Link to comment Share on other sites More sharing options...
NEV Posted May 25, 2011 Share Posted May 25, 2011 Hi Nev, Thanks for the reply, at this point I will take anything that might provide options. If you could send over the detials that would be great. P.m'd mate to your message box Link to comment Share on other sites More sharing options...
BenFromSpain Posted May 26, 2011 Author Share Posted May 26, 2011 Cheers Nev, owe you a pint! Link to comment Share on other sites More sharing options...
NEV Posted May 26, 2011 Share Posted May 26, 2011 Cheers Nev, owe you a pint! Da nada Link to comment Share on other sites More sharing options...
