yamaha flywheel puller
My bike is a 1981 yamaha DT175H ,the problem i have is i need to pull the magneto or flywheel off to change a oil seal and time the bike the manual calls for a yamaha flywheel puller part number 90890-01189 which online the cheapest was $56. bucks which is more than i want to pay for a external threaded nut with a bolt running through it, does anyone know if it is left or right hand threaded and what size the the hole the nut fits into might be,i'm thinking of just making the tool to do the job , a conventional automotive flywheel puller won't work in that tight compartment
A big list here including the one you need and from your side of the pond.
LINKY
thanks everyone i got one coming from ebay
