01 Thundercat 600
Trex9
This post is 4954 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi this is my first post so bare with me. I have an 01 thundercat that has been layed down on both sides. So instead of getting the stock turnsignals replaced i bought aftermarket leds. I have previously put new led lights on the back and have had no problem but when i went to swap the fronts out I found 3 wires: blue/red , Black, and Brown . I know what all the wires are for, but when I hook my 2 wired led lights up yellow into brown and black into black nothing seems to work. ive also tried having one stock signal on and one led. Thats when i get mixed results. I can turn the right blinker on and everything is fine but when i turn the left one on all the lights come on.when i have both leds on and I go to turn the signaler on no lights turn on in the front but both lights in the back a dimly lit. It seems like the blue/red ones need to have a place to go for everything to work, but how? whew....
ok now ive tried splicince the old lights with the new lights and still no go ive scoured and scoured all over the internet but cant find a reliable way to wire these up. I put diodes on them and i know the get juice but when i turn on the turn signal there is a low flash from the fronts and the backs are barely lit. Please help there has to be some easy solution to this. oh and if i wire up the indicator wire the just stay on and no blink at all.
