1886 FZX700 Fazer issue - cylinders one and four not firing
wize_n
This post is 4984 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Greetings,
I have an issue with cylinders one and four not firing on my 1886 FZX700 Fazer w/ Brand new NGK DP8EA-9 plugs. I suspected the Left Coil was bad since it is responsible for both one and four. In order to eliminate the left as a variable I swapped the Left Coil w/ the Right Coil (at the same time pulled all the plug wire caps) and connected them to their respective original sequence. (Left Bank Outside to #4 - Inside to #1) (Right Bank Inside to #3Outside to #2) The results were cylinders one and four still not firing. So I have eliminated the coil as the culprit. I am going to go change everything back to its respective place but thought I would see if anyone has any ideas were to look next or if you may know what the problem is here.
Thank you in advance for your help in troubleshooting.
