Changing YBR light
s1h
This post is 5287 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Afternoon,
Can anyone give me some pointers on this. I need to change the rear light on my YBR 125, bought a new light off ebay but the connections are different not quite sure what to do. Not that great on this kind of stuff.
Hopefully these pictures should help show what I am talking about.
This one is the back of the old light :
This one is the wires that are coming out of the back of the new one with a connector block :
Finally this is the 3 wires on the bike that the light connects to, fine for the old one but i cant see how to connect the new one to it.
Do I need to cut something? or need some new/different type of connection?
Thanks in advance
I take it you can't fit the spades inside the connector block, presumably the connector is female, yes? In which case you have 2 options: (1) obtain the mirror image of the connector block and wire the bike accordingly or (2) cut the block off and put the right size male spades on the ends of the wires.
I would go for option (2), good quality crimp-on spades are more than adequate for the job and are a lot more hassle-free in the long run.
You're welcome.
