Oil in Thundercat Airbox WHY!!!
uriarc
This post is 5428 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello all,
I am after a little advise / answers if possible.
I have recently picked up a 1997 Thundercat with 28000 genuine miles on it.
I have done approx 100 miles on it so far, but each time i have riden it, the next morning there has been an oil mark on the garage floor from the air box drain hose (about the size of a 50 pence peice).
Can someone tell me WHY!!!!!
Hi,
The oil would be coming from your engine breather.
The three main reasons for this are too much oil in crankcase, a well overdue oil change or a very worn motor.
If the mileage is correct and the bike has been reasonably maintained the motor should be OK.
Change the oil and filter. Use a good quality 20-50 oil and do not overfill.
Pull airbox apart and clean up excess oil.
Check plugs for oily residue and clean or replace.
If problem continues after another 100 miles have a mechanic check the compression.
Regards.
