idle sticking, 78 xs400
drprunty
This post is 5503 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Check the easy things first. Unhook the throttle cable and check for smooth/unrestricted movement. Lube it with light oil at this time. Check for proper routing as well. Make sure your carb slide moves up and down with out getting stuck. Stick your finger in there and move it and make sure it returns all the way down.
