mallorr Posted January 29, 2009 Share Posted January 29, 2009 Hello all, New to this forum. I am looking for a source for as cheap as poss speedo drive for my 2002 Fazer 600. Can any one help me. Thanks, Malcolm Link to comment Share on other sites More sharing options...
Madison Motorsport Posted January 30, 2009 Share Posted January 30, 2009 If you want cheap, try eBay or a breaker's yard. Brand new, they are only about £60 from Yamaha. Link to comment Share on other sites More sharing options...
steve m Posted January 30, 2009 Share Posted January 30, 2009 Whats wrong with the speedo drive ?? has one of the Rotor sensor lugs broken ? Part No 5VU-2517G-00-00 Rotor Sensor, (£9 ) one of the lugs broke on the wifes 600, Fowlers had them in stock. Full Unit 4YR-83755-02-00 Sensor Speed Or as Madisons says, try Ebay or a breakers. Link to comment Share on other sites More sharing options...
mallorr Posted January 30, 2009 Author Share Posted January 30, 2009 Hi All, Not stripped down yet so dont know whats broken. Just thought it was the sensor. Anyone got a pictorial diagram of that area? Regs, Malc. Link to comment Share on other sites More sharing options...
Fazer Rick Posted February 1, 2009 Share Posted February 1, 2009 The speedo on my fzs600 behaved eratically yesterday when out in Matlock bath... got home and dismantled the speedo unit and found that the speedo rotor tabs were broken... no wonder it wasn't working! I'll be ordering a new one tomorrow... maybe this is also your problem? As far as I know this is a weak spot and if the person putting the front wheel back on doesn't know the system its pretty easy to mess it up... the rotor is quite fragile. Link to comment Share on other sites More sharing options...
Fazer Rick Posted February 1, 2009 Share Posted February 1, 2009 Oh yeah - mine is completely stripped... I'll try and take a picture later and post it Link to comment Share on other sites More sharing options...
Fazer Rick Posted February 1, 2009 Share Posted February 1, 2009 The speedo unit (outside) The speedo unit (inside with rotor removed) The rotor - note that one tab is completely gone, and the other only has a very small section left The area on the wheel where is is located with the tabs Clearly you can see how it fits together... the rotor locks onto the wheel and rotates sending magnetic pulses through the speedo unit which are fed to the control box which the speedo plugs into. Hope this helps? Link to comment Share on other sites More sharing options...
mallorr Posted February 4, 2009 Author Share Posted February 4, 2009 Hi Rick, Stripped the sensor down yesterday and found that my rotor is in good orderl Looks like i have the expencive part to replace. I found info on resistance measurments wich i will make later. Waiting on price coming back from fowlers. Reg's Malc. Link to comment Share on other sites More sharing options...
